mtmj Posted June 20, 2011 Posted June 20, 2011 Year, Make, Model. 1989 Commance 4X4 Pioneer long box. No rust! Occasionally lots of mud or snow! Image, if availablehttp://sagecomp.com/Images/Imgp2234.jpg Home made 4.7 Stroker/AX-15/ 231/ Std/ Std / long Build date: (its on the driverside door sticker, in the form of month and year) Can't tell ya - all faded out. Current Location: Montana. Status: My daily driver - project truck - Hunting Fishing and geo caching rig. Notes: When I did the stroker (wife ran it out of water) I also put in a three core radiator with a non-pressurized recovery system, posi-lock front axle cable setup. Ah...it helps to be a machinist, too. Stroker has '83 Eagle 242 crank and rods, 2002 +0.060 bore pistons (with dish cut .032 deeper for reg. gas) Comp cam, offset ground crank, milled deck, Ford injectors, and a bunch of other stuff. Everything was done to keep squish in specs and compression down to regular gas. Everything works great after 30K+ miles - monster torque! AND still 21 MPG!! Pulls like crazy from 1000 to 3000 rpms. Still has std axles (3.08) but have a doner Cherokee ('87) with 3.88's. I would like to put a modest lift on it ( 2-3 inches) for chain clearance - this is Montana. Current owner: ME - 2nd owner.
littlezeeker Posted June 20, 2011 Posted June 20, 2011 Love your truck looks great hope to see it in the projects some day soon getting all beefed up keep up the good work man :wrench:
JMO413 Posted May 30, 2019 Posted May 30, 2019 VIN 1J7FJ36L3KL423566 *X8 Cloth Low-Back Bucket Seats -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 5AM Largo Tracking 5KM AMES Department Stores AHL Heavy Duty Insulation Group ALM Longhorn Southfork Package APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning HGA Hood Insulation JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon NHM Speed Control PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3 QS3 DOVER GREY MET C C SECONDARY PAINT - HS3 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Body Model JM62 Build Date 9/12/88
