kyleag89 Posted June 10, 2011 Posted June 10, 2011 Where do you guys buy your u-bolts? I need a set for the crappy D35 but I am not positive on the size or a good source to buy them.
MJRemi Posted June 10, 2011 Posted June 10, 2011 I think any spring shop or driveline shop in your area will have the correct u bolts. Just tell them which axle you have. Also, JEGS carries them and I got mine from Husky Spring online but mine were for D44.
Eagle Posted June 10, 2011 Posted June 10, 2011 Likewise, I have access to two local, old line commercial spring shops where I can get them custom bent to order. If I didn't live within range of these shops, I would start on-line with Husky Spring.
kyleag89 Posted June 10, 2011 Author Posted June 10, 2011 Thanks, are 2 3/4" u bolts the correct ID for the D35? I know they are 1/2" diameter by about 8" long for an aal.
HOrnbrod Posted June 10, 2011 Posted June 10, 2011 Try Tom at Hell Creek. Got mine there for the D44. Excellent quality and price.
MJRemi Posted June 11, 2011 Posted June 11, 2011 Thanks, are 2 3/4" u bolts the correct ID for the D35? I know they are 1/2" diameter by about 8" long for an aal. The D44 were 2 3/4" so the D35 might be a tad smaller. The 8'' should be OK but you can cut the 9'' if you want the 1" insurance. Sorry I can't be more helpful with the D35.
mvusse Posted June 11, 2011 Posted June 11, 2011 Like Eagle, I get mine custom made to order by a local shop that specialized in (mostly semi truck) suspension and brakes.
johnnyc Posted June 12, 2011 Posted June 12, 2011 The 2.75" ones will work fine with the Dana 35, which has 2,.62" tubes. That's a difference of 0.13", which is only just a bit more than 1/8". I got 1/2" u-bolts from Currie for about $6-7 each.
kyleag89 Posted June 12, 2011 Author Posted June 12, 2011 Thanks guys I'm heading to MA this morning so I will be buying everything when I get back.
