shawn Posted June 1, 2011 Posted June 1, 2011 the 2.5 is '86 and the tranny is '95. there is a 5 spd in there now. - (ba 5?).
Geonovast Posted June 1, 2011 Posted June 1, 2011 The AX-15 will bolt up to a 2.5, but you need a super rare late 90s Dakota bellhousing to do it. The only 5 speed that came behind 2.5 Jeeps is an AX-5. The BA only came behind the 4.0.
mnkyboy Posted June 1, 2011 Posted June 1, 2011 Yes its set up for the cps, Another option is the advanced adapters conversion kit,it let's you adapt the ax5 bell housing to the ax15. Only thing is its expensive
shawn Posted June 2, 2011 Author Posted June 2, 2011 i like the sound of that dakota option. last few days its seemed like shifting just isnt as good as it was (kinda slow) and my other jeeps always seemed to feel a bit more "positive".
Geonovast Posted June 2, 2011 Posted June 2, 2011 The Dakota option isn't necessarily just a -get-the-bellhousing-and-pop-it-in kind of deal. You're going to need different length driveshafts. You'll have to address the trans mount issue, and, if I'm not mistaken, there are pilot bushing and clutch problems you also need to address. Throwing in an AX-15 for it "not shifting like normal" is a little overkill. You could simply have a clutch problem, low/old oil in the trans. If you need to swap the trans, I think you'd be better off getting another AX-5.
shawn Posted June 2, 2011 Author Posted June 2, 2011 thanks correy. now that you mention it, i think youre on to something with the clutch. again, the last few days its starting to grind a bit (but just a little) when going into reverse. might be a really good call on your part. i will keep an eye on it over the next little while and see if its time for a clutch. and thank you minkyboy. youve given some good info as well.
Geonovast Posted June 2, 2011 Posted June 2, 2011 No problem. :thumbsup: I'm all for throwing an AX-15 behind a 4 popper, but for reasons more along the lines of "I've killed 5 AX-5s crawling on rocks, I need something beefier", or "I'm bored, I wanna see if I can do it." For a truck you just wanna fix and drive, another AX-5 is just easier, and they're not all that hard to find.
MancheKid86 Posted June 2, 2011 Posted June 2, 2011 thanks correy. now that you mention it, i think youre on to something with the clutch. again, the last few days its starting to grind a bit (but just a little) when going into reverse. might be a really good call on your part. i will keep an eye on it over the next little while and see if its time for a clutch. and thank you minkyboy. youve given some good info as well. mine ground when i went in reverse, because my clutch didnt engage fully :thumbsup:
