ndnx Posted May 7, 2011 Share Posted May 7, 2011 Hey guys, I took my truck into the trails the other day, which is something I don't often do, because my rear diff is in need of rebuilding and the thing usually develops a couple more rattles and clunks every time I take it off road. Anyway, I'm not sure what happened exactly, but at some point in the trip, my speedo broke. It used to wobble a lot, but now it just stopped completely. I have to work today, and before I take a look at it, I figure somebody here can give me a head's up of what to expect and how to fix it. That way I can fix it on my day off and have a good idea of what to do. Also, how much does it cost for rear differential work? I definitely need a pinion seal, bearing and possibly the pinion gear. I might have the skill to fix it myself, but that depends upon what needs to be done. Would it be cheaper to go to the wrecker's and cut out a whole rear axle from a donor? Any help is appreciated. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 7, 2011 Share Posted May 7, 2011 You probably broke the speedometer cable. As for the axle if you have a Dana 35 junk it and get another axle. If you have a M20 or Dana 44 it may be worth fixing. Diff work isn't cheap and unless you know what your doing its not something you do yourself. Link to comment Share on other sites More sharing options...
ndnx Posted May 8, 2011 Author Share Posted May 8, 2011 Yeah man, it's a 35c. That's what I thought. I'll junk it and look around for a new one. The speedo cable sounds like an easy fix. It's hooked up to the transfer case, right? Link to comment Share on other sites More sharing options...
grabber Posted May 9, 2011 Share Posted May 9, 2011 Yeah man, it's a 35c. That's what I thought. I'll junk it and look around for a new one. The speedo cable sounds like an easy fix. It's hooked up to the transfer case, right? When you replace it. replace it with a ford 8.8 or a D44 not with a D35, you can pickup a 8.8 at any j yard for 100 then switch the back breaks to Roters Link to comment Share on other sites More sharing options...
gl1200aman Posted May 13, 2011 Share Posted May 13, 2011 As for the cable, if it was wobbling up and down then quit it is the cable. It connects to the output/tail of the transfer case. Link to comment Share on other sites More sharing options...
johnnyc Posted May 14, 2011 Share Posted May 14, 2011 You didn't mention what year your MJ is. 86-90 have a cable. 91-92 have an electronic speedo. Link to comment Share on other sites More sharing options...
