WN1998 Posted December 21, 2006 Posted December 21, 2006 Well guys, I have a 92 eliminator with a 4.0 that has a junk engine. (somthing is wrong with the Cylinder closest to firewall) for piece of mind I was thinking about rebuilding the motor.) The Master kit from Napa is $759 however, I can buy a remanned with a 70k warranty 4.0 engine for $1400 shipped. What have you guys done and what do you reccomend?
Oizarod115 Posted December 21, 2006 Posted December 21, 2006 advanceauto has them for 1200 i think... don't know about their warranty though if you're going to do a rebuild kit... why not go ahead and stroke it for the same amount?
KYMJ Posted December 21, 2006 Posted December 21, 2006 Don't forget to factor in the shop work, if you rebuild yourself.
pingpong Posted December 23, 2006 Posted December 23, 2006 I would say find you a good running motor for a few hundred and swap that in. I didnt catch where you were at, but I am getting ready to pull Pong's motor, and it can be had cheap, as well as the other 4.0 I have sitting on the engine stand in the corner. Rebuildint the motor might cost more then you think. Machine work is going to run a couple hundred easy. Last time I had a block bored it was 14 bucks per cylinder, had the heads dipped shaved and magnafluxed 75 bucks a piece. Then also had the block cleaned as well. I installed my own freeze plugs as well as cam bearings (requires special tool) but I had to have them install my rods to pistons at 5 bucks a piece. I think I left the machine shop aboiut 500 bucks lighter. This as back in 97, so I don't imagine it has gotten any cheaper
sinnaevd Posted December 23, 2006 Posted December 23, 2006 when i priced mine out it was 30 bucks to have the cylinders true'd up, and more if i wanted an overbore i would look for a used engine
ejndssn Posted December 23, 2006 Posted December 23, 2006 go to a pic & pull and find a low mileage jeep motor that may suit your needs i know that they run about 100.00 around here in the beach area just have to find one that fits your needs
Duner Posted December 23, 2006 Posted December 23, 2006 I will put in my two cents. My dad has a good friend that rebuilds engines for a living so here is the scoop. Most low cost short blocks are pretty decent pieces and are warranteed decently where they cut corners is in the cylinder heads they will tighten a worn valve guides intsead of replacing guides and use good seals but these will wear within several 10k to 20k and begin smoking. Moral short blocks are good but check all torque settings before installing and have a trusted machine shop do a proper valve job on the cylinder head. Thats the info straight from someone who makes his living rebuiling engines.
