bigalpha Posted April 18, 2011 Share Posted April 18, 2011 What hardware is needed to install a rear hitch? I pulled this hitch a while ago and want to use new hardware to avoid any potential problems. Also, is there a thread on installing the hitch ... I don't remember the process for removing it. Does it use any bumper bolts? Link to comment Share on other sites More sharing options...
Dechion Posted April 18, 2011 Share Posted April 18, 2011 It depends on the hitch you have. I believe the stock ones used the bumper bolts, as do most if not all) of the aftermarkets. Do you have pics of the hitch by chance? Link to comment Share on other sites More sharing options...
bigalpha Posted April 18, 2011 Author Share Posted April 18, 2011 It's a draw-tite but I don't know what the model number is. I have a replacement bumper I'm going to install at the same time since it's not all banged up. It's really rusty in the picture but I'll be wire brushing it and hitting it with some rattle can paint before installation. Link to comment Share on other sites More sharing options...
bigalpha Posted April 21, 2011 Author Share Posted April 21, 2011 Herro. Link to comment Share on other sites More sharing options...
Dechion Posted April 21, 2011 Share Posted April 21, 2011 without seeing the side plates, I am going to say it mounts to the bumper bolts. At least I think thats where all the drawtites mounted. I think I remember reading about some 1/4" plates that neede to be installed as well, but I don't really know for sure. Link to comment Share on other sites More sharing options...
bigalpha Posted April 21, 2011 Author Share Posted April 21, 2011 Link to comment Share on other sites More sharing options...
valis Posted April 21, 2011 Share Posted April 21, 2011 There should be four little 1/4" spacers for the Draw-Tite hitch. There should already be two spacers welded to the sideplates. The hitch mounts to the rear bumper bracket locations and uses metric bolts, but I do not recall off the top of my head what the diameter, pitch, and length are. Link to comment Share on other sites More sharing options...
Motion Offroad Posted April 21, 2011 Share Posted April 21, 2011 PM us your email address and we can send you the Draw-Tite install directions in .pdf format. It shows what hardware you need and where it all goes. Link to comment Share on other sites More sharing options...
bigalpha Posted April 21, 2011 Author Share Posted April 21, 2011 PM us your email address and we can send you the Draw-Tite install directions in .pdf format. It shows what hardware you need and where it all goes. Thanks, will do. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 22, 2011 Share Posted April 22, 2011 For reference when people search. Link to comment Share on other sites More sharing options...
bigalpha Posted April 26, 2011 Author Share Posted April 26, 2011 I tried finding the hardware kit to no avail. I am not sure what hardware is needed. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 26, 2011 Share Posted April 26, 2011 Just pull out one of your bumper bracket bolts and get six grade 5 or 8 of the same size but half an inch longer. You also need 1/4 inch spacers that go between the hitch side plates and the bumper brackets, but you can use washers instead. Then you need two 2 1/2 inch bolts with lock washers, washers & nuts to bolt through the step bumper & hitch. Link to comment Share on other sites More sharing options...
bigalpha Posted April 26, 2011 Author Share Posted April 26, 2011 Is there a significant difference between G5 and G8 bolts? Link to comment Share on other sites More sharing options...
valis Posted April 26, 2011 Share Posted April 26, 2011 Is there a significant difference between G5 and G8 bolts? Grade 8 bolts are both stronger in yield and tension than Grade 5 bolts. The amount depends on the diameter bolt in question. However, the bolts in the frame are metric, therefore you'll be looking at the metric equivalent to SAE Grades, which are Class 8.8 and Class 10.9. Link to comment Share on other sites More sharing options...
bigalpha Posted April 26, 2011 Author Share Posted April 26, 2011 From what I gather, the 6 bolts that hold the hitch to the frame mounts are 10.9? Link to comment Share on other sites More sharing options...
valis Posted April 26, 2011 Share Posted April 26, 2011 From what I gather, the 6 bolts that hold the hitch to the frame mounts are 10.9? That would be a Class 10.9 bolt, which is the metric equivalent to a Grade 8. So you'll need (6) M10 x 1.50 x 43(?)mm Class 10.9 bolts to for the frame mounting positions. That's a 10mm diamter bolt with a 1.50 pitch, and 43mm (I can't read the number, but it's 40-something) length. Probably not available at too many local stores. Try searching for a local Fastenal store or a Tractor Supply - they usually have a good selection. You may also be able to find the bolts at a local Mom and Pop hardware store, too. If all else fails, order online at Mcmaster-Carr. Link to comment Share on other sites More sharing options...
bigalpha Posted April 26, 2011 Author Share Posted April 26, 2011 From what I gather, the 6 bolts that hold the hitch to the frame mounts are 10.9? That would be a Class 10.9 bolt, which is the metric equivalent to a Grade 8. So you'll need (6) M10 x 1.50 x 43(?)mm Class 10.9 bolts to for the frame mounting positions. That's a 10mm diamter bolt with a 1.50 pitch, and 43mm (I can't read the number, but it's 40-something) length. Probably not available at too many local stores. Try searching for a local Fastenal store or a Tractor Supply - they usually have a good selection. You may also be able to find the bolts at a local Mom and Pop hardware store, too. If all else fails, order online at Mcmaster-Carr. Thanks. There is a local fastener store and fastenal so I shouldn't have problems finding this bolt. Link to comment Share on other sites More sharing options...
