My 1990 (and some pics of the old '87)
So after owning 2 MJs and being on the forum for 4 yrs I figured I should finally post a few pics of the trucks, current and former.
First off, the current ride:
Maura: 1990 Renix 4.0, AX-15, NP231.
Picked her up with 117K on the clock, not running (electrical problems), leaking everything, filthy interior, steelies with bad tires, and had every dents on panel on the pass side (bed, cab, door, fender). The PO said he slid off a dirt road into a strand of trees :dunno:
I'll have to list all the mods later but I've used mostly XJ/MJ components except for the 2002 Grand AM GT seats and S-10 coolant overflow tank.
I don't have any before pics but I believe my '87 can fill in quite nicely. I swapped the ratty front bumper, some interior parts (cluster, headlight delay module, etc) steelies, and cap from the '90 to the '87 and then sold the '87.
The '87 was a Renix 2.5, AX-5, 2WD with the factory black interior and no A/C (originally from Indiana). I miss that truck but trading up to a 4.0 4WD with 80K less was too good of an opportunity to pass up. I should have taken pics of the two side by side but I had very little time available when I got the '90.
Here's a few pics of the Meg: my old '87:
I'll try to add more info later on.
Really nice and good buy. I'm glad you started a build page ill be keeping up :popcorn: And when you put in the new buckets was it the same as putting in XJ buckets or more work? Thanks
Brandon
Putting in the Grand Am GT seats was more work than the standard XJ bucket swap but they're quite comfy. :clapping: The hardest part of swapping any seats in is trying to figure out: 1. if they'll fit and 2. what adapters you have to make. The GT seats were a good choice b/c they have 4 symmetrically located bolts that secure the factory seat tracks to the steel seat base. I ended up drilling and bolting 2 pieces of plate steel to each base, then installing the MJ seat brackets in the truck. I placed the seats on the brackets and marked where to drill the plate steel. I ended up having to raise the seats with 1" spacers as the trans tunnel in these trucks is huge. The seats were perfectly located except for the fact that I couldn't close the door. Raising them 1" allowed me to slide them over just enough to clear the doors.
Here's a pic of what I ended up with:
  • 1 year later...
I haven't updated this thread in quite some time but there has been a big development. My MJ's motor is very, very tired and as of late she's been moved to the semi-retired list. I have tons of blowby, a very healthy oil leak, worn valve guides (almost constant smoke from the tailpipe), and rod knock. She'll run but is consuming & leaking about 1 qt of oil every 150 miles :eek: . I'm helping a friend rehabilitate his '90 MJ and we pulled a donor engine for him @ the jy a few months ago. He rebuilt it and we pulled his drivetrain this weekend. The motor from his '90 will be rebuilt and find a new home under the hood of my '90.
Tore the donor engine down (from the other '90 MJ) and it turns out the motor is fried. Cam bearings are gone, journal bearings are gone, crank is scored, valve guides are worn out, and last but not least there's a huge (0.030") ridge on the top of cyl #1 and 6. Add to this the crack in the top pass side bell housing bolt and this engine is in rough shape. I spoke with the machine shop and they said I'd be better off looking for another engine.
Bored 0.030" over but other than that bone stock. Right now the plan is to finish putting it together and transplant her. I did, however, run into a snag. I was checking everything out with a borescope and found a big chunk of something (cooling system sealer? Grease and sand?) in the water jacket. I had to pull freeze plug #2 to get it out. Everything else seems ok so far.
Almost fully assembled...
She runs!!!! Out on her maiden voyage (note lack of front bumper and the fact that the wiring is zip tied off the ground)
She was running poorly and, subsequent troubleshooting uncovered a bad fuel pressure regulator, vacuum leak, and exhaust leak. She runs great now :MJ 1:
I still have a leaky rear main to deal with (one of the 3 seals I didn't install myself...thanks ATK :fs1: ) but I have almost 100 miles on the new motor :banana:
I am kind of ticked about the rear main but I'll go back in and take care of it at some point. It was a ton of work but I'm glad she's running/driving again :yes: .
I started autopsying the old engine last night and found that thing was in horrific condition. Piston #1 had some weird problems with the piston ring groove for the top compression ring:
My rod bearings were in bad shape too. Take a close look at #3. Why is the backing on both sides of the rod down to copper? I'm assuming that means I spun the rod bearing? I definitely had rod knock at startup but this is pretty wild:
And of course there's #6. The piston skirt must have been cracked. None of the pistons required much force to remove but 6 came out in 2 pieces! You can see how it's scuffed on the sides as well.
