kro10000 Posted April 8, 2011 Share Posted April 8, 2011 So I know my buddies XJ has a headlight delay where if you shut off the jeep and turn the headlight switch off the headlights stay on for a few seconds. My MJ doesn't have this and I was wondering what all it takes to make it work on a non factory installed vehicle? Link to comment Share on other sites More sharing options...
JeffN Posted April 8, 2011 Share Posted April 8, 2011 my 90 comanche keeps the headlights on for about 30 seconds if i turn the truck off with the headlights on. I will have to check the wiring diagram to see if it is the same with an 89 if that is the year you have Link to comment Share on other sites More sharing options...
kro10000 Posted April 8, 2011 Author Share Posted April 8, 2011 my 90 comanche keeps the headlights on for about 30 seconds if i turn the truck off with the headlights on.I will have to check the wiring diagram to see if it is the same with an 89 if that is the year you have Yeah mine's an '89, and it definitely doesn't have the delay, or it is inoperable anyway. Link to comment Share on other sites More sharing options...
maddzz1 Posted April 8, 2011 Share Posted April 8, 2011 I'm not positive, but I think it is just something that plugs into the fuse box (like the chime module). Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 9, 2011 Share Posted April 9, 2011 There's a connector up under the driver's side dash, and the delay module just plugs in, then is fastened to the lower dash with a screw. All MJs are wired for this feature. Image Not Found Link to comment Share on other sites More sharing options...
aaronbtxnc Posted November 15, 2012 Share Posted November 15, 2012 Where can one find one of these delays? Part number, proper name? I'm searching and can't find them. Thanks, Aaron Link to comment Share on other sites More sharing options...
RDAN1 Posted November 15, 2012 Share Posted November 15, 2012 Where can one find one of these delays? Part number, proper name? I'm searching and can't find them. Thanks, Aaron The 87-90 parts book shows the part number as 56000636..I'm not sure if its available but there are some used ones on ebay from time to time for about $15.00 +/-. the JY might be a good spot to find one also...???? Edit:..Team Cherokee is selling one for $41.95....part number 56009324 which they say replaced 56000636. Link to comment Share on other sites More sharing options...
Keyav8r Posted November 15, 2012 Share Posted November 15, 2012 Contact fiatslug on this forum. He has some of these periodically. I picked one up at the local P&P. As Hornbrod's photo shows, it's tucked up behind the lower dash, may have one screw holding it (can't remember - may be Velcro'd or taped in place). I'll connect mine when I get the &@#€ truck back together and have all of the electrical demons slain. Link to comment Share on other sites More sharing options...
