codymanche Posted April 9, 2011 Share Posted April 9, 2011 so it lights up a lot or what? but I'm put hids in them not the lights it came with Link to comment Share on other sites More sharing options...
SubSonic Posted April 9, 2011 Author Share Posted April 9, 2011 so it lights up a lot or what? but I'm put hids in them not the lights it came with Yeah, that's the problem, they kinda work with the regular bulbs but with HIDs all they do is blind other drivers and make vision worse than stock. It's basically a reflector housing with a magnifying glass that only succeeds in totally f'ing up the beam pattern. I was disappointed to say the least. At least they were cheap. Link to comment Share on other sites More sharing options...
codymanche Posted April 9, 2011 Share Posted April 9, 2011 but u said they were good for offroading right then thats all I'm worried about not the other drivers. the drivers here in cali don't pay attention anyway Link to comment Share on other sites More sharing options...
SubSonic Posted April 9, 2011 Author Share Posted April 9, 2011 but u said they were good for offroading right then thats all I'm worried about not the other drivers. the drivers here in cali don't pay attention anyway I can't tell you man, I had them on for a day, then took them off yesterday because I didn't like them. Never took them off road. All I can say is give it a shot, hopefully you'll have better luck. Link to comment Share on other sites More sharing options...
mj Mike Posted April 9, 2011 Share Posted April 9, 2011 it true the drivers here in cali don't pay attention or care anyway. so it lights up a lot or what? but I'm put hids in them not the lights it came with Yeah, that's the problem, they kinda work with the regular bulbs but with HIDs all they do is blind other drivers and make vision worse than stock. It's basically a reflector housing with a magnifying glass that only succeeds in totally f'ing up the beam pattern. I was disappointed to say the least. At least they were cheap. That sux! :( ''87Warrior wrote'':The IPF housings provide a pretty good cut off, which is desired with HIDs. Link to comment Share on other sites More sharing options...
codymanche Posted April 9, 2011 Share Posted April 9, 2011 u completely went back to stock. but i don't care about cali drivers when they see this comanche coming they better get out the way or hold on lol Link to comment Share on other sites More sharing options...
mj Mike Posted April 9, 2011 Share Posted April 9, 2011 mj Mike wrote:MjAllTheWay wrote:Ok ima little confused is there a special kit that I have to use or are they all the same how do they fit into the housing. you need the H-4 H.I.D bulbs ballast's, they will fit in your autopal housings. sorry i think the autopal housings are projector also. :doh: Link to comment Share on other sites More sharing options...
SubSonic Posted April 9, 2011 Author Share Posted April 9, 2011 Nope didn't go back to stock, just went back to my diamond cut style housings with hids. Atleast the lighting is better than the others. Eventually I'll go with either autopal or hella e-codes. Anybody know if the Hellas are worth the price difference because I've read that they are a very close product? Link to comment Share on other sites More sharing options...
mj Mike Posted April 9, 2011 Share Posted April 9, 2011 ya a friend runs the hella h-4's with HID's they are a quality housing with good cut off, which is desired with HID's. so the autopal housings are not like the the other projector housings that have bad optics? & ''mj Mike'' when you had a shop install your H.I.D's how did they mount you ballast's? Link to comment Share on other sites More sharing options...
codymanche Posted April 9, 2011 Share Posted April 9, 2011 ill definatly try it out first and see what's up who knows what will happen Link to comment Share on other sites More sharing options...
SubSonic Posted April 9, 2011 Author Share Posted April 9, 2011 ya a friend runs the hella h-4's with HID's they are a quality housing with good cut off, which is desired with HID's. so the autopal housings are not like the the other projector housings that have bad optics? The "E-Mark" Autopals, (not the diamond cut) very closely resemble the Hella E-codes and are actually supposed to be of reasonable quality and have the European 'cutoff' which is great for running HIDs. I just didn't know if I wanted to get those, or pay twice/thrice as much for Hellas. Link to comment Share on other sites More sharing options...
deziped Posted April 10, 2011 Share Posted April 10, 2011 The E-pals put the light straight down the road with not much to the sides of the road. I use fog/driving lights to supplement the Pals to get better lighting to the roadside's. They do have good cut off line to limit blinding the other traffic. Link to comment Share on other sites More sharing options...
SubSonic Posted April 10, 2011 Author Share Posted April 10, 2011 The E-pals put the light straight down the road with not much to the sides of the road. I use fog/driving lights to supplement the Pals to get better lighting to the roadside's. They do have good cut off line to limit blinding the other traffic. Thanks, that's the info I was looking for. Do you know if the Hellas are any better as far as light to side? It is good to know that both have good cutoffs, which is what I had read previously. Link to comment Share on other sites More sharing options...
mj Mike Posted April 10, 2011 Share Posted April 10, 2011 from my experience the Hella E-codes that a friend runs are much like the ipf's that i run, they have awesome optic's he dose not run any aftermarket light's, it his DD. Link to comment Share on other sites More sharing options...
codymanche Posted July 26, 2011 Share Posted July 26, 2011 whats the best hids and the cheapest Link to comment Share on other sites More sharing options...
shelbyluvv Posted July 26, 2011 Share Posted July 26, 2011 whats the best hids and the cheapest http://www.bajahid.com Link to comment Share on other sites More sharing options...
comanche12 Posted July 27, 2011 Share Posted July 27, 2011 whats the best hids and the cheapest or ddmtuning.com for cheaper and still great quailty :thumbsup: Link to comment Share on other sites More sharing options...
