jeepman 87 Posted March 13, 2011 Posted March 13, 2011 How hard is it to change to a 97+ cooling system
Sir Sam Posted March 14, 2011 Posted March 14, 2011 New Radiator and source some hoses from a 91+ HO.
Eagle Posted March 14, 2011 Posted March 14, 2011 The hard part is finding a way to control the auxiliary fan, since the early system uses a sensor in the driver's side radiator tank to activate it.
RDAN1 Posted March 14, 2011 Posted March 14, 2011 The hard part is finding a way to control the auxiliary fan, since the early system uses a sensor in the driver's side radiator tank to activate it. Is it possible to buy a new radiator with a spot to mount the existing aux fan sensor? or to add one to an XJ radiator at a local radiator shop ? ?
Eagle Posted March 15, 2011 Posted March 15, 2011 The hard part is finding a way to control the auxiliary fan, since the early system uses a sensor in the driver's side radiator tank to activate it. Is it possible to buy a new radiator with a spot to mount the existing aux fan sensor? or to add one to an XJ radiator at a local radiator shop ? ? Somebody reported finding one with the bung. The ones I've seen (including the new style that the radiator shop got by accident when I ordered an old style radiator) did NOT have the bung. So I guess they exist, but I don't know where.
mvusse Posted March 15, 2011 Posted March 15, 2011 Another option is to use the original radiator with a universal cap adapter in the upper radiator hose, or use a HO thermostat housing, which has a temp sensor for the fan.
Eagle Posted March 15, 2011 Posted March 15, 2011 Another option is to ... use a HO thermostat housing, which has a temp sensor for the fan. The problem is that most sensors available are either variable-resistance senders rather than switches, or don't switch on and off at the correct temperature. Of course, if you're willing to settle for controlling the aux fan manually, with a switch on the dashboard, then there's no problem.
