1J7FT36SXML547015
xjrev10
4.0/AW4/2wd/LWB/Colorado Red
1991 Comanche Pioneer, base gauges, column shift, 177k as of today.
Location, Northeastern MN
Build Date, 10/90
Bought vehicle in Feb 2011 from the 3rd owner (3rd owner never even transfered the title or used the truck). Replaced all brake lines and installed a new fuel tank and currently using it as a DD for work. Jeep is bone stock save for the Dodge Dakota wheels. (as I was told)
Its rusty but I hope I will be able to save it. This one is 3rd in line tho. Runs excellent, cruise control works, window washer works, bench seat is wore out. I have all service records from when it was new and purchased in the Twin Cities at a dealership. Records run from new to 2005.
  • 4 years later...
  • 4 years later...
*B1 TRIM STYLE B1 - CLOTH && VINYL BENCH SEAT
-SA CHARCOAL
153 Zone 53-Minneapolis
1AA U.S. Dealer Retail
3V3 Customer Preferred Discount
ADA Light Group
ADH Heavy Duty Electrical Group
ALN Body Color Bumper Group
APA Monotone Paint
ARL 300 Premium Group
BAF 130 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNC Sun Visors w/Illum Vanity Mirrors
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K27 Do Not Use
K2B STRIPE/BADGE/MOLDING/COLOR
K3R STRIPE/BADGE/MOLDING/COLOR
KKS STRIPE/BADGE/MOLDING/COLOR
KWS STRIPE/BADGE/MOLDING/COLOR
LAJ Headlamps On Warning Chimes
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE Door Armrest Storage Lamp
LDA Underhood Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
NHM Speed Control
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBC Compact Spare Tire
TBM Tire Carrier Winch
TMW P265/60r18 BSW A/S All Terrain Tires
TZH Michelin Brand Tires
WJD 15X7.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z59 Left Front Spring Group Ix
Z78 Right Front Spring Group VIII
Body Model TL62
Build Date 10/29/90
  • 1 year later...
