mj Mike Posted March 20, 2011 Author Share Posted March 20, 2011 finished the return lines & cooler :wrench: had to notch my air filter ''splash guard'' :thumbsup: Link to comment Share on other sites More sharing options...
dakineJ Posted March 26, 2011 Share Posted March 26, 2011 Nice work, great thread. Thanks for posting this up. These project's are definitely on my to do list. Your engine bay is lookin' pretty good .... but I suppose you hear that all the time, haha. :thumbsup: Link to comment Share on other sites More sharing options...
mj Mike Posted March 28, 2011 Author Share Posted March 28, 2011 :cheers: thanks!! soon i will be ride of all hose clamps & plastic Quick disconnects :banana: except coolant :fs2: Link to comment Share on other sites More sharing options...
valis Posted June 13, 2011 Share Posted June 13, 2011 DIY AN Clutch line install: -3AN fitting for "pin" type Clutch Master Cylinder: http://www.advanceadapters.com/products/pn-716130/ -3AN 60" SS braided hose with one straight fitting and one 90: http://www.racepartsolutions.com/prodde ... od=FRA3000 -3AN to 7/16"-24 hard line fitting: http://www.racepartsolutions.com/prodde ... od=FRA6502 Link to comment Share on other sites More sharing options...
NC Tom Posted April 22, 2023 Share Posted April 22, 2023 Resurrecting this ancient thread. Has anyone done this upgrade to remove the plastic clip connector but also keep the OEM metal fuel lines? I really hate those plastic clips and like to have them gone. Link to comment Share on other sites More sharing options...
Pete M Posted April 29, 2023 Share Posted April 29, 2023 I'm seriously debating it now that one of the cooler lines won't friggin' let go. lol. but you should probably put your Q in Tech so more eyeballs will see it. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted April 30, 2023 Share Posted April 30, 2023 Yes you can use these fittings that convert hard lines to AN. You will need to cut the flare off. Use a male one end female the other. NPT Male Hard Line Adapter - Black - Aluminum | AN Plumbing Link to comment Share on other sites More sharing options...
