SOA gives anywhere from 5 to 6.5 depending on the condition of your leafs and the specific perches you use. 2wd MJ leafs typically sit a bit lower than 4wd leafs.
no. drop pitmans should only go in if you also get a drop bracket with the trackbar. messign with the angles can induce bumpsteer (meaning as the suspension moves up and down, it can literally turn the steering wheel out of your hands)
Pete, Can you put dimensions on that drawing? :brows:
actually, I left them off on purpose. I fear that on "paper" the numbers look close enough that guys might think they can just bolt in that XJ axle without moving the perches. and that's bad.
I'm just looking for the fixed X-axis SOA/SUA dimensions from the flanges or centre-to-centre for XJ and MJ perches if you have them. :cheers:
I wanna say the MJ is 42 and the XJ is just shy of 44. lord only knows if my poor brain is remembering that right. :dunno:
