coil springs
I'm running about 8" of lift but didnt want to constrict my self to just the 8" spring so i purchased the ACOS and 6" skyjacker springs so i had the ability to adjust and fine tune my suspension as things settled or as i threw more weight on it.
coils won't casue tires to wear bad.
Of course they will. An alignment on a Y-link steer Jeep depends on a static height. Bowing coils will lower that height and toe out the front end ergo higher tire wear. Not to mention the control arm adjustment isn't spot on any longer either.
