If that's your truck...
Paint the flares and the rockers black. Leave the rest red. You can use Fusion Satin or flat bedliner spray.
I already did that a while back. Thank you tho
Factory two-tones:
I'm sorry guys when I said under side I mean like Diff covers, axles and what not. I was thinking about red and black but don't rly know what to paint under there you know?
Thanks
Brandon
you can paint anything you want to really. the steering linkage, diff cover and trac bar are usually what most paint. some paint knuckles to control arms to, hell anything that can be painted. IMO just those main three are enough
I painted my trackbar, front diff cover, draglink, tie rod and the rake backing plates black 8)
Just watch for overspray and use a wirebrush and some sandpaper to most of the surfaces then clean them with alcohol wipes or something so the paint stays there
I would say paint anything you feel comfortable removing. I wouldn't try to paint anything on the truck unless its black and you can't see the over spray. The tie rod and diff covers are easy to remove, clean, sand, prime, and paint. :wrench:
I tried to paint the diff cover but its after market and powder coated so it kinda failed :( how ever I did paint my new rear 8.8 and it looked brand new. ya'll can check it out on my build in like a week or 2 lol. Thanks for the info guys
Brandon
paint the underside of your truck electric lime green :ack: :doh:
How did you know thats what I was looking for that or...maybe this? images?q=tbn:ANd9GcT_3v08iEaTM9M_LtRHDAR5n3-XlCFDQduzSwn99xJqhBlF1uPW&t=1
Brandon
