Kenbob Posted January 17, 2011 Share Posted January 17, 2011 To get those rotting graphics off the side of my truck I found that besides using heat to get the big chunks off, using acetone and a razorblade knife (the ones used for removing inspection stickers) works well IF and a big IF you drag the blade toward you instead of pushing with the blade. Dragging it toward you with a light hand will get the glue off without wrecking the paint. It will take few swipes. Link to comment Share on other sites More sharing options...
Eagle Posted January 17, 2011 Share Posted January 17, 2011 The key is to let the acetone soften the adhesive. Link to comment Share on other sites More sharing options...
mule13 Posted January 17, 2011 Share Posted January 17, 2011 wd-40 pb blaster and those type penetrants work great for dissolving glue also. where i work we get vehicles with stickers all over everywhere i just spray them with pb blaster and wait about 10 minutes then scrap them with a scraper.I'm not sure what effect it has on paint long term when I'm done i spray window cleaner on the area and clean it up that way.pb blaster is good for when you stuff on your hands that go-jo won't take off too like jb weld lol. sparay and let it sit a few minutes and it comes right off. Link to comment Share on other sites More sharing options...
Automan2164 Posted January 17, 2011 Share Posted January 17, 2011 There is a good write up from goblazers in the diy section. Rob L. Link to comment Share on other sites More sharing options...
1974CJ5 Posted January 18, 2011 Share Posted January 18, 2011 A product called remove-it. Made by chroma graphics out of tennessee is a great product also, easy on paint, and easy on you, but when it weakens the adhesive it leaves a greasy residue, but it is easily cleaned. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted January 18, 2011 Share Posted January 18, 2011 Where were you guys when I was removing the decal on my 88? The PO had just tried to sand the decal off, which still left tape and a butt load of adhesive and gouged up the body. Eventually I discovered that I could rub it down with acetone or Xylol and the tape would soften up, then it just zipped right off. Wiped down with Xylol to remove the adhesive. The hardest part was getting the tape off where it had been sanded. Nice to know there are some better products out there. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted January 18, 2011 Share Posted January 18, 2011 An eraser wheel for a handheld drill is all you need. Worked great on removing my decals- even took the ancient adhesive right off. A quick once-over with Goof-Off or Goo-Gone and you'd never know there was ever decals there. Link to comment Share on other sites More sharing options...
Darren Posted January 18, 2011 Share Posted January 18, 2011 viewtopic.php?f=9&t=22152 Link to comment Share on other sites More sharing options...
