88swampedmj Posted December 6, 2005 Share Posted December 6, 2005 well i have had my comanche about 3 weeks now and have only driven it once..before i bought it..when i got it home it needed a new steering column and a few wires were melted on the ignition...i put another column in and fixed the wires...now the jeep won't get any power inside the cab..it stops at the fuse box i think... a few days ago my friend slammed the passenger door and all the power came on!! i then tried to start it and the power went back out..then lastnight i went outside and the dang thing was purrin..the power came on and the fan came on...i don't know what it could be??? ive never messed with wiring.. any suggestions? Link to comment Share on other sites More sharing options...
whowey Posted December 6, 2005 Share Posted December 6, 2005 You have two MJ's listed in your sig, which one are you referring to? I would check the C101 connector. Its the big one up on the firewall near the brake booster and MC. Pull it loose and make sure all the pins are clean and straight. Lots of funky electrical gremlins can happen because of that bad boy. Then start going through and tightening all the chassis grounds. Link to comment Share on other sites More sharing options...
87manche Posted December 7, 2005 Share Posted December 7, 2005 then check all of the fusible links at the starter relay. THen check the fuse box to make sure it's not deformed from brake luid from the clutch master if it's a 5spd. Link to comment Share on other sites More sharing options...
88swampedmj Posted December 9, 2005 Author Share Posted December 9, 2005 thanks for the tips guys...whats a sig though..i didnt realize i had two comanches listed Link to comment Share on other sites More sharing options...
87manche Posted December 9, 2005 Share Posted December 9, 2005 the signature you have on the message board. It shows two comanches. One 86 the other 88. We need the year, engine, trans and any other pertinent info before offering suggestions. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 9, 2005 Share Posted December 9, 2005 One's a cherokee and the other's a comanche... Link to comment Share on other sites More sharing options...
pingpong Posted December 9, 2005 Share Posted December 9, 2005 Same thing isnt it :roll: :P Just a cherokee wanting to be a truck :wink: Link to comment Share on other sites More sharing options...
88swampedmj Posted December 9, 2005 Author Share Posted December 9, 2005 my comanche is an 88 sb 4x4 4.0 5pd.. my cherokee is an 86 4d 4x4 2.8 v6 5pd.. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 10, 2005 Share Posted December 10, 2005 pingpong said: Same thing isnt it :roll: :P Just a cherokee wanting to be a truck :wink: That depends how much you love your sawzall. Link to comment Share on other sites More sharing options...
88swampedmj Posted December 10, 2005 Author Share Posted December 10, 2005 87manche said: the signature you have on the message board. It shows two comanches.One 86 the other 88. We need the year, engine, trans and any other pertinent info before offering suggestions. i only have one comanche....for now! the comanche has an ax15 5spd Link to comment Share on other sites More sharing options...
87manche Posted December 10, 2005 Share Posted December 10, 2005 well, having an man trans rules out a NSS. Did you put an ohmeter to the fusible links? Do you have power at the ignition switch? Have you tried jumping the starter solenoid? Link to comment Share on other sites More sharing options...
Frankensteinsmj Posted December 18, 2005 Share Posted December 18, 2005 88swampedmj, have you determined your problem yet? let me know cuz I think I know whats up. Frank C Link to comment Share on other sites More sharing options...
88swampedmj Posted December 20, 2005 Author Share Posted December 20, 2005 no i havent figured it out yet...i think its a short and the power is not getting through the fuse box.... iam thinkin of takin it to a shop soon! Link to comment Share on other sites More sharing options...
Frankensteinsmj Posted December 20, 2005 Share Posted December 20, 2005 88swampedmj, I think your problem is related to the steering column you replaced. On the column under the dash on the right hand side there are 3 wire connectors. One is a long thin one that clips on to the column. Above that connector are two sockets on the column. I would push those two in and make sure they have a good connection. You will see on one of the connectors a heavy gauge yellow wire so you know that you are looking at the right wire connectors. Let me know if this is it. Thanks Frank C Link to comment Share on other sites More sharing options...
88swampedmj Posted December 23, 2005 Author Share Posted December 23, 2005 well that wasnt it...i think i may just take it to a shop and let them look at it...ive tried all i can... Link to comment Share on other sites More sharing options...
