Still idling a bit high and stumbling . . .
Truck normally idled at 750rpm, now its idling at 850-950rpm and it still has a slight shake n shimmy at idle . . .
New parts:
air filter, plugs, wires, cap, and rotor.
Last tune up I used the cheap stuff, silver cap n rotor kit, econo wires, and autolight copper plugs, Ran great for 7,000ish miles then picked up the rough idle and sluggishness.
This tune up I used the gold cap n rotor kit, premium wires, and busch Fusion +4 plugs, Starts faster and has noticeably more power better fuel mileage, but still not what it. Was, Still has the rough idle and some sluggishness.
Truck has been checked 5-7 times for vac leaks and have found none . . . 9K miles on fuel pump, 5K miles on fuel filter, Map sensor, TPS, and O2 sensor.
Mike
idle air control valve is on your throttle body.. take it out and clean it, see if that helps, carefull with the liquids its easy to break it. if that doesnt help check your pcv or ccv valves and grommets depending on your engine. if those don't help then check all of your vacuum lines and gaskets (intake,exhaust)
