foreman1063 Posted December 30, 2010 Share Posted December 30, 2010 It doesn't look like the rubicon retainer plate bolt pattern matches the xj d44 backing plate bolt pattern. Link to comment Share on other sites More sharing options...
87Warrior Posted December 30, 2010 Share Posted December 30, 2010 Here is my next question: has anyone tried to use an Aluminum ZJ 44 axle for its brake parts? This axle will probably have bigger tubes and therefore the caliper bracket may just fit perfectly over the axle...? The disk assembly I have is from a D44a. I am probably mistaken, but I was under the impression all ZJ disks were the same. And an excerpt from WoodKrawler's build on JF: To adapt the ZJ disc brakes to the XJ/MJ Dana 44 I used the following parts and process: Parts: ZJ Backing Plates - Junkyard ZJ Dust Shields - Junkyard ZJ Calipers - Junkyard ZJ Rotors - Advance Auto ZJ Ebrake Shoes - Advance Auto ZJ Ebrake Hardware - Advance Auto New Axle Bearings and Seals - Came with my TEN Factory Shafts Jeep TJ/Rubicon Rear Disc Brake Retainer Plates Process: Enlarge the center hole of the backplates to allow the seal/bearings to pass through Using the retainer plate from the XJ Shafts as a template drill/enlarge bolt holes on the ZJ backing plate and dust shield as well as on the Rubicon retainer plate. Link to comment Share on other sites More sharing options...
johnnyc Posted December 30, 2010 Share Posted December 30, 2010 Here is my next question: has anyone tried to use an Aluminum ZJ 44 axle for its brake parts? This axle will probably have bigger tubes and therefore the caliper bracket may just fit perfectly over the axle...? Yes, I got the parts for my 8.25 from a ZJ D44A. The tubes were pretty close between the two axles, so not much grinding was needed. So do tell what your parts recipe was! I thought I already did. :) Explorer backing plates, reman calipers from Kragen, Centric pads and rotors, Raybestos e-brake shoes, Rubicon retainer plates, braided brake hose, KJ e-brake cables. I accumulated all the parts over a period of time, so maybe it just feels inexpensive. Link to comment Share on other sites More sharing options...
foreman1063 Posted December 30, 2010 Share Posted December 30, 2010 Did the ruby retainer or the 8.8 backing plate bolt right on or did you have to re-drill either to match the 44 bolt pattern? Link to comment Share on other sites More sharing options...
91coMANche Posted December 30, 2010 Author Share Posted December 30, 2010 Here is my next question: has anyone tried to use an Aluminum ZJ 44 axle for its brake parts? This axle will probably have bigger tubes and therefore the caliper bracket may just fit perfectly over the axle...? Yes, I got the parts for my 8.25 from a ZJ D44A. The tubes were pretty close between the two axles, so not much grinding was needed. So do tell what your parts recipe was! I thought I already did. :) Explorer backing plates, reman calipers from Kragen, Centric pads and rotors, Raybestos e-brake shoes, Rubicon retainer plates, braided brake hose, KJ e-brake cables. I accumulated all the parts over a period of time, so maybe it just feels inexpensive. Sorry sorry! My mind works in lists...reading the paragraph is tough to quantify but reading a list and I get it! So other than a little opening up on the caliper brackets did you have to do any other fabrication? I assume you got the explorer backing plates with the caliper brackets together. Link to comment Share on other sites More sharing options...
johnnyc Posted December 30, 2010 Share Posted December 30, 2010 The backing plates/caliper brackets are a one-piece unit. Link to comment Share on other sites More sharing options...
