sinnaevd Posted November 30, 2006 Share Posted November 30, 2006 we just finished a putting a fuel injected 302 into a YJ, not the same i know but it works extremely well we used the AX15, stock jeep axles, jeep t-case other then the motor mount movement and and a few minor electrical problems everything went nice and easy dunno if the AMC 360 is anything like the dodge, but if they are i would say no on that one, personal choice though Good Luck!! Link to comment Share on other sites More sharing options...
comanchedude Posted November 30, 2006 Share Posted November 30, 2006 I vote for the AMC engine,thats what I would like to see in a Comanche as that was still an AMC/Jeep if you can afford to but if you want the cheap way, the Chevy is the only other choice :( Link to comment Share on other sites More sharing options...
feerocknok Posted November 30, 2006 Share Posted November 30, 2006 I voted Chevy, because they are everywhere. No matter what problem you have, someone else has had it, whether it's in a Chevy or a Jeep. I also like the 360 idea, but only because old Dodge trucks and full-size Cherokees can be had for pocket lint, well, $500 pocket lint, while Chevy trucks tend to be $1500+. Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 30, 2006 Author Share Posted November 30, 2006 yeah, if i went 360 it would be a JEEP 360 just for brand loyalty. my brother had a 360 grandwaggy so he knows all about the carbuerators on them and all that good stuff. he spent a month making his run right (had sat for 2 years before he bought it) does anyone know if a 4.0 rad would work with a 360? EDIT: scannin through novak a little bit, and it popped into my head that i don't really need 5 speeds considering I'm about to be running 32's or larger on 3.07 gears. 4 speed with granny 1st would be perfect. and i could avoid re-gearing for a long time. aka 465 or something comparable Link to comment Share on other sites More sharing options...
Druville Posted November 30, 2006 Share Posted November 30, 2006 ive toyed around with doing a v8 when my engine craps out on me, I'm a chevy guy up and down. parts are way cheap and easy to come by, and if you don't buy new and rebuild one yourself you can get about 350hp crank for 1000-1500. just ask my last motor for my camaro. arnt there like 50million small block chevys out in the world or something like that. when in doubt follow the masses. Link to comment Share on other sites More sharing options...
BRC 88MJ Posted November 30, 2006 Share Posted November 30, 2006 Oizarod115 said: does anyone know if a 4.0 rad would work with a 360? I have my doubts. I was using a 4.0 radiator to cool a 4.3 Chevy V6 and it worked okay as long as I was moving. In mild to hot weather, it would start to overheat if I sat in traffic or the truck idled in place for too long. I was only using a single electric fan without a shroud so that was probably part of the problem. Link to comment Share on other sites More sharing options...
Pete M Posted November 30, 2006 Share Posted November 30, 2006 Cooling is always a concern with anything bigger than the 4.0L. If it was going into my rig I'd get an engine with aluminum heads (or even an aluminum block if I could afford it) to keep the weight down and it MUST have fuel injection. Carbs just ain't my thing. But then my plans are for a stroker 4.0. Bolts in and makes good power. :D Link to comment Share on other sites More sharing options...
