91coMANche Posted December 9, 2010 Posted December 9, 2010 My truck has a rear slider window but it sits outside the sheetmetal by about 3/4". I am not sure if it is factor or aftermarket. Does anyone have a picture of a factory rear window they wouldn't mind sharing with me?
og3r Posted December 9, 2010 Posted December 9, 2010 My truck has a rear slider window but it sits outside the sheetmetal by about 3/4". I am not sure if it is factor or aftermarket. Does anyone have a picture of a factory rear window they wouldn't mind sharing with me? hope this helps. previous owner siliconed a plexi glass sheet in place of the broken out part, and then I locked the doors without realizing the key doesn't work, so I had to break it to get in lol.
91coMANche Posted December 9, 2010 Author Posted December 9, 2010 Ah so that is factory. Mine is not factory. I guess I should find one before I get her painted soon. I'll be pulling the back window anyway.
RDAN1 Posted December 9, 2010 Posted December 9, 2010 My truck has a rear slider window but it sits outside the sheetmetal by about 3/4". I am not sure if it is factor or aftermarket. Does anyone have a picture of a factory rear window they wouldn't mind sharing with me? Mine sits outside the sheet metal also.. but only about 1/4 inch...Is the window supposed to have rubber weatherstripping around it on the outside to seal it to the metal? or?
91coMANche Posted December 9, 2010 Author Posted December 9, 2010 Mine has a rubber gasket and then a frame that sits 3/4" to 1" outside the sheetmetal. I don't think its factory. It doesn't bother me but it doesn't seem factory.
64 Cheyenne Posted December 9, 2010 Posted December 9, 2010 My 88 has a factory slider swapped in, uses a factory rubber gasket. My friend has an 86, his slider is aftermarket, has a faux look to the metal trim. Looks like a rubber gasket, but no rubber gasket used. Gonna guess on this, rubber gasket-factory. No gasket-aftermarket.
87Warrior Posted December 9, 2010 Posted December 9, 2010 Factory? Dealer installed? Something from the mid 90's? I don't know. My rear slider also sits out about 3/4" and the gasket around the window frame is rubber. It was on the truck when I bought it. Edit: Wow, my 1,000th post!!!
RDAN1 Posted December 9, 2010 Posted December 9, 2010 Gonna guess on this, rubber gasket-factory. No gasket-aftermarket. :agree:
Dirteatr717 Posted December 10, 2010 Posted December 10, 2010 Mine has a rubber seal around the outside and a gasket... Nobody else has owned my jeep either :D
