87Chief Posted November 30, 2010 Share Posted November 30, 2010 Will a header (exhaust manifold) from a 97-03 wrangler fit on my 2.5L 1987 Comanche chief ? I really need one. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 30, 2010 Share Posted November 30, 2010 you will need to modify the downpipe area of it, and make a custom down pipe, but in the long run, it will bolt up to your head, at least. Link to comment Share on other sites More sharing options...
87Chief Posted November 30, 2010 Author Share Posted November 30, 2010 Crap. Lol I can't find any 2.5L from a cherokee or Comanche near me... :( Link to comment Share on other sites More sharing options...
87Chief Posted November 30, 2010 Author Share Posted November 30, 2010 What will I need to take off to put a new one on? Air box and all? Link to comment Share on other sites More sharing options...
kar120c Posted November 30, 2010 Share Posted November 30, 2010 If you want a high quality 2.5 header go with Banks Power. Jegs and Summit should have it. Cheaper route would be Pacesetter. Link to comment Share on other sites More sharing options...
87Chief Posted November 30, 2010 Author Share Posted November 30, 2010 Didn't see any 2.5L Link to comment Share on other sites More sharing options...
Motion Offroad Posted November 30, 2010 Share Posted November 30, 2010 Pacesetter does not make a XJ/MJ 2.5L Header. Banks does not make a XJ/MJ 2.5L Header. 51316 (YJ/TJ) has clearance issues to the best of my knowledge. Borla does not make a XJ/MJ 2.5L Header. 17061 (YJ/TJ) has clearance issues with down pipe. Dynomax does not make a XJ/MJ 2.5L Header. You could use just the header portion of the 88741 kit, and than modify or make your own downpipe. To the best of my knowledge I do not know of a manufacture out their making "performance" 2.5L headers for the XJ or MJ. You may be able to use the header of one of the above kits and make your own downpipe though... Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 30, 2010 Share Posted November 30, 2010 Pacesetter does not make a XJ/MJ 2.5L Header. Banks does not make a XJ/MJ 2.5L Header. 51316 (YJ/TJ) has clearance issues to the best of my knowledge. Borla does not make a XJ/MJ 2.5L Header. 17061 (YJ/TJ) has clearance issues with down pipe. Dynomax does not make a XJ/MJ 2.5L Header. You could use just the header portion of the 88741 kit, and than modify or make your own downpipe. To the best of my knowledge I do not know of a manufacture out their making "performance" 2.5L headers for the XJ or MJ. You may be able to use the header of one of the above kits and make your own downpipe though... agreed. Link to comment Share on other sites More sharing options...
87Chief Posted November 30, 2010 Author Share Posted November 30, 2010 I am not looking for a high performance header... Just one that is not rusted, or in good condition. Link to comment Share on other sites More sharing options...
brdhntr Posted December 1, 2010 Share Posted December 1, 2010 i wonder if clifford makes 1? they have alot of 4cyl and inline 6 products and may have a replacement option as well as a performance option. Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 1, 2010 Share Posted December 1, 2010 I am not looking for a high performance header... Just one that is not rusted, or in good condition. Here's an exhaust manifold on e-bay. http://cgi.ebay.com/ebaymotors/Dorman-OE-Solutions-674-225-Exhaust-Manifold-_W0QQcmdZViewItemQQhashZitem588b1a285eQQitemZ380290869342QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Link to comment Share on other sites More sharing options...
airspeed Posted December 1, 2010 Share Posted December 1, 2010 Clifford does make a header for the 2.5L. I had one installed on my engine before I put it back in the truck, I just didn't like the way it fit. The stock cast iron header extends about 12" below the intake manifold and mates to the down-pipe. The down-pipe goes down and crosses over behind the oil pan and is supported in a bracket. The clifford header extends to the bottom of the oil pan and then bends straight back toward the transfer case. It would take some custom exhaust work to get it to mate to the cat on the other side of the car. I think the price of the Clifford was about $300!! I put a new stock manifold on my 2.5 and 10k miles later it has a crack, you can here the tick-tick-tick when I first start it up. If Clifford could make their header mate to the down-pipe on a Comanche I would buy it! Link to comment Share on other sites More sharing options...
87Chief Posted December 1, 2010 Author Share Posted December 1, 2010 Where did you find your manifold? Autozone, Advance, etc.? Link to comment Share on other sites More sharing options...
airspeed Posted December 1, 2010 Share Posted December 1, 2010 http://www.cliffordperformance.net/ Be prepared for some custom exhaust work for this header to fit a 2.5 Comanche. Link to comment Share on other sites More sharing options...
87Chief Posted December 1, 2010 Author Share Posted December 1, 2010 Ok thanks. Now if there was a hole in the exhaust manifold.. It would puff out whenver it sparked? The it's not doing that just a constant smoke coming from under the manifold.. Link to comment Share on other sites More sharing options...
Geonovast Posted December 1, 2010 Share Posted December 1, 2010 A hole in the manifold would constantly push out exhaust. Nothing to do with when it sparks. Pushing out exhaust is a good 4th of what your cylinder does, and there's always at least one piston doing it. Rockauto has a manifold for $70, or a $90 one that comes with 1 Manifold gasket, 2 studs, 2 nuts, 2 washers, 2 5/16inch Bolts, 2 5/16inch Lock Washers, 1 Oxygen Sensor Plug, 1 EGR Gasket, 1 Block-off Plate Link to comment Share on other sites More sharing options...
