kyleag89 Posted November 6, 2010 Share Posted November 6, 2010 Ok so I have to change my wheel U-joints, but I can't get my wheel hubs out. On my fathers truck I used a 12 point socket to remove the three bolts, but mine are far too rusty to use a 12 point. Anyone have any ideas, other than grinding the heads off and having to buy new wheel bearings and trying to find 6 new bolts? Link to comment Share on other sites More sharing options...
foreman1063 Posted November 6, 2010 Share Posted November 6, 2010 If the heads are too rusty to get a 12 point socket or wrench on, try one of the sockets designed for damaged bolt heads. Also heat the area of the knuckle around the bolts. Heat does wonders for loosening up rusty bolts. You'll have to replace the bolts but if they're that rusty you probably should anyway. Link to comment Share on other sites More sharing options...
Geonovast Posted November 6, 2010 Share Posted November 6, 2010 They're a 12 point 13mm head. Soak them with PB, a lot, and try a wire brush to clean up the heads. I don't think the bolt-out sockets will work very well, as those suckers are torqued down quite a bit. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 6, 2010 Share Posted November 6, 2010 If you have room to clean them up, soak them with PB, and then start with a 1/2" 12 point, as half inch is slightly smaller than 13mm, then go to 12 mm 12 pt socket hammered on if the half don't work. Good luck. Link to comment Share on other sites More sharing options...
kyleag89 Posted November 6, 2010 Author Share Posted November 6, 2010 Thanks, Do you think I can buy new bolts from the stealership? The only store around that even sells bolts around me is the home depot or lowes. I'm sure you guys know they have a very limited selection of bolts. Link to comment Share on other sites More sharing options...
Eagle Posted November 6, 2010 Share Posted November 6, 2010 Dealer is probably the ONLY source for those bolts. Link to comment Share on other sites More sharing options...
kyleag89 Posted November 7, 2010 Author Share Posted November 7, 2010 Ok good to hear. Thanks eagle Link to comment Share on other sites More sharing options...
kyleag89 Posted November 7, 2010 Author Share Posted November 7, 2010 Check these out! Look like they were made for a Comanche wheel hub! HAHA http://www.harborfreight.com/hand-tools/sockets-accessories/7-piece-3-8-eighth-inch-metric-spline-socket-set-96362.html Link to comment Share on other sites More sharing options...
mvusse Posted November 7, 2010 Share Posted November 7, 2010 After having split many 3/8" drive sockets on those bolts, I have to disagree. 1/2" drive socket is a must, unless you want to run the the store to exchange a broken socket each time you need to remove a unit bearing. Link to comment Share on other sites More sharing options...
Geonovast Posted November 7, 2010 Share Posted November 7, 2010 I've always been able to pull mine out with a 12 pt box wrench, using the two wrench trick to pop it loose, then a ratcheting wrench to work it out. Link to comment Share on other sites More sharing options...
foreman1063 Posted November 7, 2010 Share Posted November 7, 2010 I've always been able to pull mine out with a 12 pt box wrench, using the two wrench trick to pop it loose, then a ratcheting wrench to work it out. I don't live in the rust belt so really never had a big problem removing mine. As as a rule though, when reinstalling I always put anti-seize on the bolts, heads and around the unit bearing surface, where it fits in the knuckle. Cheap insurance for future removals. Link to comment Share on other sites More sharing options...
