ComancheAssault Posted November 4, 2010 Share Posted November 4, 2010 Hello, I am new here. I'm looking to buy a 92 Jeep Comanche from a used car dealer here and the dealership told me that the Comanche is in good condition but the 4WD Actuator is in need of replacement. I thought to myself no problem. Now I'm trying to find a 4WD Actuator online and could you perhaps suggest a good brand. It could be OEM as well. Thanks. Link to comment Share on other sites More sharing options...
Geonovast Posted November 4, 2010 Share Posted November 4, 2010 92 shouldn't have a CAD... unless it was a replacement axle, or it used to be 2wd. Just lock the CAD. viewtopic.php?f=9&t=18415 Link to comment Share on other sites More sharing options...
neverstuck Posted November 4, 2010 Share Posted November 4, 2010 4wd actuator( if the guy is correct) is the vacuum operated $#!& collar thatt engages the front pass. side axle. (look for vacuum lines and a housing thing on your pass side behind the rear tire axle area Link to comment Share on other sites More sharing options...
neverstuck Posted November 4, 2010 Share Posted November 4, 2010 neverstuck said: 4wd actuator( if the guy is correct) is the vacuum operated $#!& collar thatt engages the front pass. side axle. (look for vacuum lines and a housing thing on your pass side behind the rear tire axle area And the actuator itself is quite expensive; i have two on reserve for that reason. once you find what I'm talking about take off the bolts that hold it on and look look for a big c thingy and a couple of axles. If your on level ground not too much gear oil will leak out. Lemme know Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 4, 2010 Share Posted November 4, 2010 If it is the axle disconnect that you are reffering to, you can lock it into the always on position, and forget about it.... the newer models did this anyways, so no big deal. If you do want to keep it functional, there are kits available that use a cable mechanism to move the axle disconnect assuming that an original is too expensive or unavailable. To know for sure what your problem is we really need more information. I juts hope the dealer isnt calling the transfer case an actuator..... should just be an easy fix....BUY IT! Link to comment Share on other sites More sharing options...
mvusse Posted November 4, 2010 Share Posted November 4, 2010 As the first reply stated, the 92 model year NEVER CAME WITH A DISCONNECT FRONT AXLE. As such, the transfer case does not have a vacuum switch to operate one. Link to comment Share on other sites More sharing options...
Eagle Posted November 4, 2010 Share Posted November 4, 2010 I have never heard of anything called a 4WD "actuator" and I find myself wondering just what the heck this used car shyster is talking about. I suspect it may be the transfer case. Link to comment Share on other sites More sharing options...
Geonovast Posted November 4, 2010 Share Posted November 4, 2010 mvusse said: As the first reply stated, the 92 model year NEVER CAME WITH A DISCONNECT FRONT AXLE. As such, the transfer case does not have a vacuum switch to operate one. Not entirely true. I used to think the same about 91, but my Dad's 91 XJ had a factory CAD system. Also, the 92 model year DID come 2wd, and it's entirely possible a CAD 4wd system was used to convert it. Link to comment Share on other sites More sharing options...
ComancheAssault Posted November 4, 2010 Author Share Posted November 4, 2010 Thanks guys for all your infos. This will help me eventually in my DIY after purchase of the 92 Comanche.Yesterday, I spoke with the dealer and he gave me the part number and his OEM supplier of parts for his business.He referred to a clueless me at first the part that was in need of purchase. Quote DORMAN 4WD ACTUATOR -- This high quality 4WD actuator directly replaces OE number 8350 3113; With Dorman's limited lifetime warranty. Note that the part is for a 86-87 Comanche and I have to find the exact part for the 92 Comanche. Called up the site and the op told me that they are expecting the actuator for the 92 Comanche next month.Then me and the dealer got on an argument: Quote Me: Fix the jeep first and I'll buy it.Dealer: Son, buy it and DIY fix it. Its simple.Me: No way man, I'd rather look elsewhere for a fault free Comanche.Dealer: Your loss kid, goodluck finding your Comanche elsewhere. Uncle Ernie Sells the Best Cars. Owning a Comanche btw is one of my teenage dream. Link to comment Share on other sites More sharing options...
Geonovast Posted November 4, 2010 Share Posted November 4, 2010 You need to take a look under the front and see if it even has a CAD. Seriously, even if it has a CAD, and the actuator is fubar, just lock it over and forget it's there. Link to comment Share on other sites More sharing options...
Eagle Posted November 5, 2010 Share Posted November 5, 2010 Geonovast said: Seriously, even if it has a CAD, and the actuator is fubar, just lock it over and forget it's there. :agree: You'll replace the actuator, and then find out that what was really bad wasn't the "actuator" at all, but the vacuum harness that activates it. I don't even know if that's still available. When it was, it sold for about $25. Then you'll change that, and discover that the problem really wasn't the actuator OR the vacuum harness, but a busted shift fork inside the disconnect. Just slide it over manually, shim it in place, and forget it. There are write-ups on exactly how to do it in the DIY area here. Link to comment Share on other sites More sharing options...
mvusse Posted November 5, 2010 Share Posted November 5, 2010 And again, if it is stock, a 92 MJ does not have that part. The front axle is always engaged with 4wd operation being controlled by the transfer case only. Link to comment Share on other sites More sharing options...
danbyrambler Posted November 5, 2010 Share Posted November 5, 2010 I'm new here too, but....the 5th digit of the VIN will tell you if it left the factory as a 4wd or 2wd - I've no info on '92s but a search should pull the letter code for you or call a Jeep dealer. RM Link to comment Share on other sites More sharing options...
neverstuck Posted November 6, 2010 Share Posted November 6, 2010 Interesting, tell him you want atleast 400 off the price of it for having to fix the supposed "actuator" I hate car salesmen, but there the only ones that sell cars :thwak: Link to comment Share on other sites More sharing options...
neverstuck Posted November 6, 2010 Share Posted November 6, 2010 neverstuck said: Interesting, tell him you want atleast 400 off the price of it for having to fix the supposed "actuator" I hate car salesmen, but there the only ones that sell cars :thwak: btw, some 92's did come with cad Link to comment Share on other sites More sharing options...
