how to remove door lock cylinder
I just had to take off the inside door panel. then with the window up I was able to reach in using a tool to remove the clip that holds the cylinder in place. then I pulled the lock cylinder out a little and unhooked the rod that is connected to it.
No you don't need to remove the glass. If the clip holding it in is stuck,like mine were, remove the black rubber thing on the side of the door (its actually a plug to give you access to a bolt for the door handle) and stick a long screwdriver in there against the clip and tap it with a hammer.
