TheMagician Posted September 25, 2010 Share Posted September 25, 2010 There is a tube that is not connected to anything. It has a plastic cap with a hole on the end, looks like a vent tube maybe. My trucks runs fine, I was just wondering what it may be for. :dunno: 1992 Jeep Comanche, 4.0 6cyl, manual 5 spd, 2wd short bed. Here is a link to the picture. I also found other connections that are not connected to anything, I created a album with pics of all the connections. If you could help me with these other connections let me know, I will send the links to the pics, thanks. Link to comment Share on other sites More sharing options...
Eagle Posted September 25, 2010 Share Posted September 25, 2010 I don't see anything in your photo that matches your description of what you are asking about. Link to comment Share on other sites More sharing options...
Automan2164 Posted September 25, 2010 Share Posted September 25, 2010 I don't see anything in your photo that matches your description of what you are asking about. Eagle, he's talking about the hose that runs parallel with the main loom, that has a hose barb sticking out of it I believe. Rob L. Link to comment Share on other sites More sharing options...
carnuck Posted September 25, 2010 Share Posted September 25, 2010 Haven't played with mine in awhile. Window washer? Link to comment Share on other sites More sharing options...
TrailReadyMJ Posted September 25, 2010 Share Posted September 25, 2010 Haven't played with mine in awhile. Window washer? :agree: Looks like the washer fluid hose to me too. Link to comment Share on other sites More sharing options...
TheMagician Posted September 25, 2010 Author Share Posted September 25, 2010 Automan 2164, yes you are correct. I am talking about the rubber hose with the white line and the plastic pointed end on it. My wiper fluid works fine. I do need to find out why my wiper blades do not drop all the way to the bottom of the windsheild when I turn them off, they stop about half way. Link to comment Share on other sites More sharing options...
freakjeep93 Posted September 25, 2010 Share Posted September 25, 2010 thats normally your wiper linkage getting work out. theres a DIY on here for replacing the bushings. Link to comment Share on other sites More sharing options...
Carl'sMJ Posted September 26, 2010 Share Posted September 26, 2010 viewtopic.php?f=9&t=8325 This is the DIY Topic I used as a guideline when I replaced my wiper linkage bushings. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted September 26, 2010 Share Posted September 26, 2010 Put air or vacuum to it see what happens. Be careful with air pressure, you don't want to blow something up. Link to comment Share on other sites More sharing options...
TheMagician Posted September 29, 2010 Author Share Posted September 29, 2010 You guys where right. The hose turned out to be for a rear wiper unit. I have a MJ and this hose it not used. I checked out a XJ the other day, that hose connects to another hose that runs to the rear wiper washer. Thanks guys for the help. By looking at this XJ with the same 4.0 6cyl engine I was able to find out what every wire was for that is not connected on my MJ. My MJ is a base model 5 speed 2WD so I do not have all the extra's. Link to comment Share on other sites More sharing options...
