aperseghin Posted September 7, 2010 Share Posted September 7, 2010 my 88 comanche 4.0 is missing the power comfort button. the wiring is there, the button /switch is missing... anyone got a spare they can send me? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 7, 2010 Share Posted September 7, 2010 any factory fog light switch will do...go to the junkyard and nab one. Link to comment Share on other sites More sharing options...
Pete M Posted September 7, 2010 Share Posted September 7, 2010 I would just wire it in as power and leave it there. :thumbsup: all Jeeps (after they got rid of that button) were wired that way. the comfort button only changes the shift points (and it really only matters when you floor it). Link to comment Share on other sites More sharing options...
aperseghin Posted September 7, 2010 Author Share Posted September 7, 2010 how do i wire it for power.. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 7, 2010 Share Posted September 7, 2010 middle wire gets wired to bottom wire, IIRC. just make a jumper for it with two male spade connectors, then tape them in. Link to comment Share on other sites More sharing options...
aperseghin Posted September 7, 2010 Author Share Posted September 7, 2010 do you happen to know what the colors that get wired together are, the connector is hanging loose so there is not to and bottom Link to comment Share on other sites More sharing options...
Pete M Posted September 7, 2010 Share Posted September 7, 2010 does your truck drive? Link to comment Share on other sites More sharing options...
valis Posted September 7, 2010 Share Posted September 7, 2010 I can nab one for ya next time I go to the junkyard. I have a spare, but it's missing the faceplate, for lack of a better term. You can plug it in, but can't select power or comfort. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 7, 2010 Share Posted September 7, 2010 the black one is the ground, so the other two get wired together. use a test light from the center to either side, see which one grounds out the light. then wire from the center to the one that does NOT ground the light out. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 7, 2010 Share Posted September 7, 2010 Yes, I have one, switch + correct faceplate that you can plug your connector to. Shoot me a PM if you need it. But I agree w. all the above - you don't need the COMFORT setting, so you might as well just hardwire it. :D Link to comment Share on other sites More sharing options...
aperseghin Posted September 7, 2010 Author Share Posted September 7, 2010 the black one is the ground, so the other two get wired together. use a test light from the center to either side, see which one grounds out the light. then wire from the center to the one that does NOT ground the light out. define "ground out" i am not used to reading this term. do you mean the light should be on or off Yes, I have one, switch + correct faceplate that you can plug your connector to. Shoot me a PM if you need it. But I agree w. all the above - you don't need the COMFORT setting, so you might as well just hardwire it. :D PM sent Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 7, 2010 Share Posted September 7, 2010 the light would be on. I'll get you the colors soon as I get the wiring out of the parts truck today. Link to comment Share on other sites More sharing options...
aperseghin Posted September 7, 2010 Author Share Posted September 7, 2010 awesome.. thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 7, 2010 Share Posted September 7, 2010 PM sent Reply sent. Link to comment Share on other sites More sharing options...
aperseghin Posted September 7, 2010 Author Share Posted September 7, 2010 looks like I'm only missing the actual rocker switch.. i have this plastic peice that has a light. the light is off and there is no way to turn it on.. lemme go take a pic. Link to comment Share on other sites More sharing options...
