Theoretically it's there to dampen the engine vibration as the 2.5 is a rough running little beast with no balance shafts. The 4.0 is a better balanced engine and doesn't need it. Not sure what would happen if you ran without one though. :dunno:
They were always zero balanced (inline 4 and inline 6 are inherently balanced) but at lower RPMs any differences in the compression would make them shake slightly so the shock was added to dampen the vibes. The 6 cyl is also smoother because it fires more times between each revolution.
Picture someone firing a gun. You know that recoil? The same thing happens when the cylinder fires. Guy with a machine gun doesn't move around as much when he fires because it fires in such rapid succession.
Gotcha! Figgured inlines should be "naturally" balanced, but didn't know about the shaking due to compression differences. Makes sense! Like your recoil illustration!
