pederl Posted August 20, 2010 Share Posted August 20, 2010 I am connecting a new gas tank to a 1989 Comanche 6ft bed. I need a place where I can buy the valves and gaskets on top of the tank, any ideas? Thank you. Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted August 20, 2010 Share Posted August 20, 2010 Give napaonline a try. http://www.napaonline.com/Search/Detail ... 99+3999999 Link to comment Share on other sites More sharing options...
gl1200aman Posted August 20, 2010 Share Posted August 20, 2010 Valves? Do you mean the complete fuel pump assembly with the sender unit? If yes, is it an exact match for the original tank or is it from something else and you are making it fit? If it is the original the closest that I found is available here: http://www.northernautoparts.com/ProductModelDetail.cfm?InventoryId=94775 Others have said that it is not the exact same but it does work. You just need to experiment with the fuel level and gauge reading to know if the gauge is correct and before you run out. Link to comment Share on other sites More sharing options...
Jeepman Posted August 20, 2010 Share Posted August 20, 2010 I am not sure the Vent/Roll over valves are available anywhere but used or the dealer... Part Number J536 0058 Lots available thru your Local dealer for Around $18.00 each The Grommet is 52018823 And is around the same money... Link to comment Share on other sites More sharing options...
1987Comanche Posted August 21, 2010 Share Posted August 21, 2010 Cherokee rollover valves and grommets are identical and XJs are plentiful at the JY. Link to comment Share on other sites More sharing options...
