dual gas tanks?
I was cruising around on line and found a S10 4x4 site where the guy used the stock tank under the bed along with a blazer tank which is located behind the rear axles for a "stock" dual gas tank set up, has anybody ever tried anything like this with the comanches and a cherokee gas tank?
from what i would think, i don't think it would work. the tank on XJs sit up in the rer so they don't hang out below the rear end. also it would really be in the way for an MJ that does any sort of off-road stuff that needs the nice angle in the back. best way i figure to do duals would be use a fuel cell in the bed. but rather then that just use as big of a cell you can fit in the bed and remove the stock tank. just my .
Alex
