1JTHS6412HT001663
AMCJeepMJ
This is my rig. Beige clearcoat with tan interior. Pink, black, and silver factory hood and side decals. Bench seat. 162K miles (as of July 2010, 175K as of July 2011, 191K as of Dec 2012).
When purchased in 2007:
In 2010:
Engine: 2.5 I4 / Trans: AX-4 / Transfercase: N/A / Front axle: Solid beam / Rear axle: Dana 35 / Base Model
Build date: August 21, 1986
Current Location: Pacific Northwest USA, Oregon, Central Oregon
Updated Dec 2012:
Status: Still on the road as driver. Originally purchased at Smolich Jeep/Dodge in Bend, Oregon in fall of 1986 as a 1987 model. Currently resides less than 20 miles from where it was purchased new. Clutch and cylinder replaced Feb 2011, radiator/hoses replaced Nov 2011, steering column replaced December 2012 with like-new rebuilt column from http://www.columnsgalore.com/ with Celebrity Eurosport leather two spoke steering wheel. Original 10 hole grille reinstalled. Rear slider window installed April 2012.
Notes: Summer wheels are 16" Silverstars, Winter wheels are 15" powdercoated Gamblers. Blue canopy/topper of unknown make. Hella H4 headlights, reverse floodlights under rear bumper. Amber KC fog lights on front bumper. 1" front spacers, 1" rear shackles, 2" AAL rear springs. Dual air horns. Dent in drivers' door and cab corner. Mopar smoked bug deflector. Addco rear sway bar, poly front sway bar bushings and end link bushings, Spidertrax rear wheel spacers in summer. Factory COMANCHE bedliner.
Update March 2013:
Replaced water pump and thermostat March 2013, replaced headliner Feb 2012, also installed EZ Cool insulation. RuffTuff saddle blanket seat cover installed March 2013. LED license plate, glove box, and interior b-pillar lights installed. 100w headlight harness upgrade installed.
Current owner: Me.
  • 1 year later...
January 2016 update:
Now have replaced the alternator and water pump [sep/Oct 2014], and painted the fiberglass canopy to match [beige] and new LED light installed to illuminate the bed. Now 213k on it. Amber KC lights are now gone, and headlights are Hella H4s.
Lower air dam extended by modifying an 80's S10 air dam, for aero purposes. Grill slots partially blocked on sides, again for aero purposes.
  • 7 years later...
  • 1 year later...
Body Model TL61
*X1
-YY
APA MONOTONE PAINT PACKAGE
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DCB Transmission - 4-Speed Manual,
EPD ENGINE - 2.5L I4 TBI GAS
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
PYM
QYM
SBA POWER STEERING
TBG SPARE TIRE - COMPACT
WMC BASE WHEEL DRESS - UP (INCLS TRIM RING)
  • 7 months later...
