5 seconds to start
What year is it? Renix era?
EDIT: Not abnormal for a Renix. You might look at the distributor cap for corrosion on the rotor contacts, plugs and boots are tight, plug wires, the normal HV ignition stuff.
Try turning the key forward for a few seconds first (into the 'run' position, to get the fuel pump up to pressure), then start.
It works for my 98 XJ (sometimes i forget, and it takes 5-6 seconds).
My 89' MJ is also a slow starter (5-6+ seconds), and the 'key forward first' trick does not work.
Cleaning the CPS might help you.
Tho it didn't help me,
neither did a new cap & rotor, plugs, wires, fuel filter, etc (<--- it needed that stuff anyway, but didn't help with the cranking issue)
you can try both cleaning the CPS as well as unplugging it and cleaning up the terminals inside the connector. the CPS sends a pretty weak signal anyways and anything that degrades that signal will cause the computer to wait longer until it's absolutely positive of the location of the engine before firing.
