CWLONGSHOT Posted July 14, 2010 Share Posted July 14, 2010 What is preferred? POLY or RUBBER? I have poly in the TJ and they are fine, but kinda hesitate in the MJ with the uni-body MJ... :no: :dunno: What do you all think?? CW Link to comment Share on other sites More sharing options...
cracker Posted July 14, 2010 Share Posted July 14, 2010 Either works fine. The polly doesn't isolate the vibrations as well. I prefer the rubber myself. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 14, 2010 Share Posted July 14, 2010 I prefer the rubber myself. X2. Poly will shake your brain out.... Link to comment Share on other sites More sharing options...
dasbulliwagen Posted July 15, 2010 Share Posted July 15, 2010 Poly will also transfer more noise into the body... ran them on most of my VW's, thats probably why I have tinitus and am half deaf! Or it could have been the wide open stinger exhausts I had! :nuts: Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 15, 2010 Share Posted July 15, 2010 if mounts are bad, does it sound like a blown shock? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 15, 2010 Author Share Posted July 15, 2010 In my case, I just have a little clunk when I let off the gas. I was underneath looking at the tract of water from the drip pans and noticed they where badly dry rotten from the bottom. What little can be seen of them from the top looks fine. CW Link to comment Share on other sites More sharing options...
ratrapp Posted July 15, 2010 Share Posted July 15, 2010 i've got the brown dog mounts and they are kinda harsh.maybe the softer of the two styles would be better.i cheaped out and got the classic style because the softer ones were a little more expensive.in hindsight i should've got the softer ones. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 15, 2010 Share Posted July 15, 2010 get the brown dog or M.O.R.E. motor mounts...with the factory LCA bushings. 3 years running them for me, still no issues. Link to comment Share on other sites More sharing options...
