Steering wheel column?
Hey guys.
I drove my mj the other day and when I got in I noticed the steering wheel moves... You can move it around like it's loose. But it also rides to the right... Any help will be appreciated!
Thanks
The wiggle (UJoint) that lets the column tilt is loose. You want to tighten the 4 bolts, if I remember right, that holds it together B4 any of the bearings fall out. Requires removing the steering wheel, locking plate and turn signal assembly.
The procedure to tighten up a loose GM tilt column is all over the Internet. I don't have it bookmarked because I don't have one, but someone here posted a link to one of the writeups within the past few weeks (IIRC).
You wouldn't happen to know anything about AMSoil would you?
As a matter of fact, no. However, there is a member on here that is an AMSoil distributor or just a guru on it. Can't remember them right off hand but they have it in there sig.
  • 1 month later...
