Caravan Lift Gate Question ANy techs on here?
sinkrun
Just bought a 98 caravan for my bussiness the hatch would not open. We did manage to pop it open thru the hole on the inside lubed some spots adjusted the rod works great now. But I need to get the lock cylnder out its is frooze up. We finaly got the plastic bolt that I believe is what you need to remove to get the handle out but it just spins. Any suggestions?
When I bought my 99 XJ, the lock cylinder for the hatch was frozen up too. Not sure what part of it was, but I doused the key in PB, stuck in it, and took it out. Repeated 4 or 5 times, had to redo it again the next day, but it's been fine since.
