1eliminator1 Posted July 1, 2010 Share Posted July 1, 2010 i just put 2 inch spacers up front, so are shackles the only way to level it out? Link to comment Share on other sites More sharing options...
ComancheKid45 Posted July 1, 2010 Share Posted July 1, 2010 or AAL :cheers: Link to comment Share on other sites More sharing options...
wranglercory Posted July 7, 2010 Share Posted July 7, 2010 Might be cheaper to add leafs from a Explorer or a truck spring with more acrh. Link to comment Share on other sites More sharing options...
Geonovast Posted July 7, 2010 Share Posted July 7, 2010 Go AAL, longer shackles aren't really the way to go, especially for 2 inches. Link to comment Share on other sites More sharing options...
MjPioneer Posted July 7, 2010 Share Posted July 7, 2010 Shackles are a little :nuts: somtimes. They have a tendancy to turn your leafs into a flat peice of wood rather then lifting your rig. Using a shackle on its own I don't support but should you toss an AAL in there and then through on a shackle thats a little better imo Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 7, 2010 Share Posted July 7, 2010 Just be sure to do a FL A a L OR as suggested a full leaf(s) from another spring pack with more arch. As mentioned a shackle alone isn't the best idea for this amount of lift. A JKS 1.5" lifted XJ shackle is a nice replacement to the thin factory shackle. But will offer no additional lift, just a better angle, strength and overall better function of your spring pack. CW Link to comment Share on other sites More sharing options...
Pete M Posted July 8, 2010 Share Posted July 8, 2010 i just put 2 inch spacers up front, so are shackles the only way to level it out? Hellcreek has an AAL kit that should bump it up an inch or so. Did you align the front after the lift? Link to comment Share on other sites More sharing options...
