freakjeep93 Posted June 30, 2010 Share Posted June 30, 2010 how do i remove the engine bay harness from my 88 2.5L mj? Link to comment Share on other sites More sharing options...
freakjeep93 Posted June 30, 2010 Author Share Posted June 30, 2010 did a bunch of searching and it seems that there is a 1/4 bolt in the connecter i have to remove. ill look for that and report back Link to comment Share on other sites More sharing options...
freakjeep93 Posted June 30, 2010 Author Share Posted June 30, 2010 okay so i ofund it and the stupid bolt is completly rounded off :fs1: :headpop: any suggestions on what to do to get it out now? Link to comment Share on other sites More sharing options...
Pete M Posted June 30, 2010 Share Posted June 30, 2010 Are you inquiring about the fuse box? Link to comment Share on other sites More sharing options...
freakjeep93 Posted June 30, 2010 Author Share Posted June 30, 2010 no the engine bay harness. its all torn up around the connector on the firewall so i need to replace it. but i know now how to remove but i can't because the bolt is stripped. Link to comment Share on other sites More sharing options...
Pete M Posted June 30, 2010 Share Posted June 30, 2010 I'd drill out the head of the bolt. Link to comment Share on other sites More sharing options...
freakjeep93 Posted June 30, 2010 Author Share Posted June 30, 2010 yea i think thats what i may have to do . its just kinda hard to get anything in there to work with Link to comment Share on other sites More sharing options...
kastein Posted July 1, 2010 Share Posted July 1, 2010 Are you sure it's 1/4"? I seem to recall it being a 6 or a 7 mm bolt. If you don't mind going the "path of no return" route, you can use a sawzall to cut away at the connector body till you can get at the head with a pair of vice grips. Disconnect the battery first! Link to comment Share on other sites More sharing options...
freakjeep93 Posted July 1, 2010 Author Share Posted July 1, 2010 yea i thought of that today. i only tried 2 sockets for some reason but it does seem to be stripped. I'm going to play with it more tomorrow and see if i can get it. reson i think its 1/4 is becasue in my reading here someone said it was 1/4 Link to comment Share on other sites More sharing options...
Eagle Posted July 2, 2010 Share Posted July 2, 2010 freakjeep93 said: yea i thought of that today. i only tried 2 sockets for some reason but it does seem to be stripped. I'm going to play with it more tomorrow and see if i can get it. reson i think its 1/4 is becasue in my reading here someone said it was 1/4 Try metric sockets. The MJs, especially the early ones, were a maddening mix of metric and SAE fasteners. And use 6-point sockets, not 12-point. Link to comment Share on other sites More sharing options...
freakjeep93 Posted July 2, 2010 Author Share Posted July 2, 2010 thanks ill try my metric sockets after work tomorrow but I'm still pretty sure its stripped. i don't use 12 point sockets on anything i strip enough bolts as it is lol Link to comment Share on other sites More sharing options...
WBKrazy Posted July 2, 2010 Share Posted July 2, 2010 just took mine out yesterday.... it's a 6.5mm.... kind of an odd size, i happened to have one cuz it came with a super cheap chinese socket set i got :rotf: Link to comment Share on other sites More sharing options...
freakjeep93 Posted July 2, 2010 Author Share Posted July 2, 2010 thanks for the info I'm gunna get that bugger out today Link to comment Share on other sites More sharing options...
