1J7FT26L1LL143621
500 MJ
1990, Jeep Comanche, Base.
Stock Configuration:
4.0L / AW-4 / D35 / SWB
Notes: I bought this truck on December 14th, 2007. It had 100,286 miles on it then and it was completely stock. I think that the factory color of this truck was Pearl White. It had a gray interior with a bench seat. The rear window was a one piece window, the wing windows were fixed. The truck did have Air Conditioning, but no power options, with the basic gauge cluster and column shift transmission shifter. The truck came with factory 10 hole steel wheels and black center-caps. No evidence of any previous uni-body damaging accidents.
Current Configuration:
4.0L (Original) / AW-4 (Original) / D35 (Original)
Notes: The truck is now painted multiple shades of white (whatever white spray bomb can was handy) The bed has inherited the drop in "Comanche" bedliner from my 1988 MJ as well as rec'd a Delta Champion Toolbox. The front bumper has been modified to accept $500 MJ's Front Tow Points. The interior is essentially stock. Air Conditioning has been completely removed from the truck. A 10 slot grille and fender badges from an '86 MJ have been added to the truck (not shown in pic). The motor is stock, with the addition of a Hesco Hi-flow Waterpump. The trans is stock. The rear axle is stock. The front axle is stock with the addition of Frozen Rotors slotted brake rotors. Wheels are 15 x 8" Jeep TJ Canyons. Current Mileage 114,500.
Build date: Not Known
Current Location: Fitchburg, Wisconsin. The truck was bought in Laurium, Michigan (I know I am at least the fourth owner - previous owner bought the truck from "University Auto Used Car Dealer, Sebastian Florida" - Sticker is still on the tailgate).
Status: Daily Driver & Weekend Traveler
Current & Forever owner: Brent Marsh
I am going to keep this page up to date with the changes this truck goes through, there are still lots of things that are planned, I don't think it will ever be "done". This page was last updated on 6-20-2010.
  • 8 years later...
*E1 Cloth Bench Seat
-SA Charcoal
166 Zone 66-Orlando
1AA U.S. Dealer Retail
5KK First American Title Insurance CO.
ALA SE Decor Group
ALK Italia Package
APA Monotone Paint
BAY 105 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KDB STRIPE/BADGE/MOLDING
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Body model TL61
Build Date 9/19/89
  • 1 year later...
