1eliminator1 Posted June 2, 2010 Share Posted June 2, 2010 every time i take off there is a knocking from under my mj. and every once in a while i will turn sharply and feel vibration. is tht just my rear end binding up and is this normal? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 2, 2010 Share Posted June 2, 2010 I don't think thats normal man Not sure what it could be yet, but I'm pretty sure its not supposed to do that Link to comment Share on other sites More sharing options...
Pete M Posted June 2, 2010 Share Posted June 2, 2010 check to see if your exhaust is contacting your transmission crossmember. :thumbsup: Also check you U-joints for slop. Link to comment Share on other sites More sharing options...
DJM/78 Posted June 2, 2010 Share Posted June 2, 2010 U joints are a great start but a thunk or knock can come from almost anywhere . My problem was mostly steering but the most noticeable clunk came from the track bar bracket . They tend to loosen overtime , more common with a mild 2"-3" lifts with the stock bracket , I ended up welding mine , dammed thing came loose like three times . Link to comment Share on other sites More sharing options...
maddzz1 Posted June 3, 2010 Share Posted June 3, 2010 Does it happen when turning or when going straight? Link to comment Share on other sites More sharing options...
1eliminator1 Posted June 3, 2010 Author Share Posted June 3, 2010 well i recently checked and i have a bad u-joint. gonna replace both of them though because they have 115,000 miles on them Link to comment Share on other sites More sharing options...
