Drivetrain noise after trying to pull tree stump
New member with a 90' MJ 2 wheel drive 2.5 that is making what I thought was a
driveline noise (checked the u-joints, their OK). Anybody have any ideas?
Its speed related and doesn't matter if the clutch is in or out, kind of a click, click.....
Thanks
How did you check the u joints?
Could also be internal to the axle.
I wish it was a rock in the tire.
I pulled the driveline out and balanced it (I build them for a living)
The thing was wildly out of balance but u-joints OK.
I was suprised these things use tiny 1310 joints.
Anyway still make the noise, its also load related
going uphill its light but downhill it really knocks
Happened to me on an XJ - it was the spider gears in the diff. Much worse coasting down a hill than with a load on the diff. Pull the diff cover and take a peek- it will probably be obvious - hopefully. :cheers:
I was figuring chipped pinion/ring gear teeth, sounds like you got lucky there. Maybe you warped/bent a tooth slightly? Not even sure that's possible with how hard they are, figure they'll probably break instead.
Where does the sound seem to come from?
