pitbull4x4 Posted May 24, 2010 Share Posted May 24, 2010 I know a question about dome lights again. But mine is Bass Ackwards. They stay on all the time when I try to put the lights in from Advance Auto. The old ones did not come on at all and would not stay in. The new ones stay on with the doors shut and will not go off with the light switch on the dash. Where do I go from here? Link to comment Share on other sites More sharing options...
mfpdm Posted May 24, 2010 Share Posted May 24, 2010 Uhmm, you do know that the light has three functions depending on the postion of the lens right. (ON, OFF, and SWITCH) Change the position of the lens and see what happens. Oh and if you knew all that, check to see if one of your door switches is bad. :cheers: Link to comment Share on other sites More sharing options...
Wildman Posted May 24, 2010 Share Posted May 24, 2010 And if you just replaced the dome lights with some off the shelf lights, you could have them wired wrong, with using the always "hot" wire. Read thru this - viewtopic.php?f=9&t=3490 Link to comment Share on other sites More sharing options...
pitbull4x4 Posted May 27, 2010 Author Share Posted May 27, 2010 The lights are the ones from Advance. I checked the wiring and it is right. Where do I go from here? :dunno: Link to comment Share on other sites More sharing options...
beepbeepmyredjeep Posted May 27, 2010 Share Posted May 27, 2010 Were the lights functional before replacement? Have you tried opening and closing both doors? Check your dome light switch inside the door frame. Sounds like it may not be functioning properly. It's possible both switches went bad. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 27, 2010 Share Posted May 27, 2010 I still think youre wired wrong.... just my 2 cents. Link to comment Share on other sites More sharing options...
pitbull4x4 Posted May 28, 2010 Author Share Posted May 28, 2010 Yes, the lights worked in the other Comanche. Opening and closeing doors, lights stay on. Light switch on dash will not turn them off. I will check the door switches and dash switch again. I cut the wires on the other truck off so I would know which way to hook them up in this truck. I asked the Pitbull and she barked. I don't speak barking. If someone does come and help. :rotf: :rotf: Link to comment Share on other sites More sharing options...
Harper Posted May 28, 2010 Share Posted May 28, 2010 She say, "rrrrrrufff, rewire!" Link to comment Share on other sites More sharing options...
