manimal Posted May 21, 2010 Share Posted May 21, 2010 was there ever a full console made for a column shift automatic MJ/XJ? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 21, 2010 Share Posted May 21, 2010 no. Link to comment Share on other sites More sharing options...
Geonovast Posted May 21, 2010 Share Posted May 21, 2010 No reason you can't use a full console though, and just put either a plate or a bucket where the shifter would go. Link to comment Share on other sites More sharing options...
beaterjeep Posted May 21, 2010 Share Posted May 21, 2010 Just fab up a blank piece to fit in the shifter bezel area, and cut a hole in it for a built in drink holder! Link to comment Share on other sites More sharing options...
Darren Posted May 21, 2010 Share Posted May 21, 2010 Turn the shifter hole into a built-in 6-pack cooler. Just make sure it's deep enough for tall-boys. Link to comment Share on other sites More sharing options...
manimal Posted May 21, 2010 Author Share Posted May 21, 2010 HAHAHA You guys are funny.........tall boys :cheers: . I have thought about making a gauge panel right there. It's not for mine,but I have to do the work for my friend.Thanks -Lance Link to comment Share on other sites More sharing options...
kastein Posted May 22, 2010 Share Posted May 22, 2010 Another idea if you want to do a manumatic (manually controlled automatic, baja shifter, etc) setup is you could leave the stock floor shifter installed as well as the column shifter and use one for automatic mode and the other as the manumatic shifter. Link to comment Share on other sites More sharing options...
