JeepcoMJ Posted May 21, 2010 Share Posted May 21, 2010 tomorrow morning, I'm going up to beaterjeep's place to fix the electrical issues on the cherokee, and bring his '88 comanche home. the '88 is rust free, has a dent in the driver's side b pillar and front of the bed. it's a longbed, 4 cylinder 5 speed 2wd. the trans is junk, the rear axle has unknown gears due to a swap, and the front brakes are fubar'd. the wiring harness is junk due to some unfortunate wiring done to the heaterbox. I have a '96 cherokee (compliments of Automan) 4 cyl 5 speed 4x4. automan needs the axles back, but the rest is mine. I want to put the rest back in beaterjeep's comanche. and I'd like to remove the dents, replace the front fenders, figure out a roll pan for the rear, swap in either a 4.10 geared 8.25 or 8.8 with disc brakes. unknown if it will remain 2wd or 4wd, that will depend on the condition of the front spindles. then I'd like to paint it, at least with a base pearl white so he can build off of that for his paint scheme. his interior will also be swapped, including racing buckets. would anyone like to have a wrench-athon to at least get it and the '95 stripped, and everything swapped in? I can do all the fine details as time passes. Thanks, Pat Link to comment Share on other sites More sharing options...
89eliminator Posted May 21, 2010 Share Posted May 21, 2010 have to work Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 21, 2010 Author Share Posted May 21, 2010 lol, I don't mean do it tommorrow. I mean we need to pick a weekend. Link to comment Share on other sites More sharing options...
beaterjeep Posted May 21, 2010 Share Posted May 21, 2010 Don't forget, I also have the Waggy header panel to go with too! But, that's complete, so it's an easy swap over. Pick a weekend, I'll see if I can make it. :rotf: Link to comment Share on other sites More sharing options...
500 MJ Posted May 21, 2010 Share Posted May 21, 2010 Be easier if you say dates that you would like to do this and then I can try and make it. My summer plans are changing everyday. Link to comment Share on other sites More sharing options...
