ComancheKid45 Posted August 19, 2010 Share Posted August 19, 2010 ^^^ Truck looks good :thumbsup: Alrighty so when I swap a Dana 44 in my SWB (from a LWB if it matters) I will either need a new driveshaft or to find a place to shorten mine? I'm currently sitting +1.5" in the rear and plan to go about another 2" withen the next year or so, will shortening the driveshaft now be a problem with an extra 2" or so whenever? Link to comment Share on other sites More sharing options...
pamike Posted August 19, 2010 Author Share Posted August 19, 2010 ^^^ Truck looks good :thumbsup: Alrighty so when I swap a Dana 44 in my SWB (from a LWB if it matters) I will either need a new driveshaft or to find a place to shorten mine? I'm currently sitting +1.5" in the rear and plan to go about another 2" withen the next year or so, will shortening the driveshaft now be a problem with an extra 2" or so whenever? you will need your shaft shortened. even with my axle at full droop with my truck sitting on jack stands my shaft wouldn't fit into the truck. i had it shortened exactly 1" and the slip yoke is in about the same spot it was. i don't think the driveshaft will need to be lengthened at 3.5 " of lift. the only way your stock shaft will work is if you put enough lift on your truck to make up the 1" difference Link to comment Share on other sites More sharing options...
mvusse Posted August 19, 2010 Share Posted August 19, 2010 Running ~7-8" lift in the rear including Chevy drop shackles. I run an axle with a 1" longer nose than the stock one, use a YJ yoke, which is 0.75" longer than the Comanche one, and still the yoke was 1" farther out than it used to be. Don't know about 3.5", though. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 20, 2010 Share Posted August 20, 2010 Alright. Does anyone possibly have a measurement of a SWB 4x4 rear drive shaft with a Dana 44 rear? Just to have a number to work with :cheers: Link to comment Share on other sites More sharing options...
johnnyc Posted August 20, 2010 Share Posted August 20, 2010 If you don't get an answer this morning, I can measure my old D44 shaft when I get home. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 20, 2010 Share Posted August 20, 2010 Still no answers.....measure away Link to comment Share on other sites More sharing options...
johnnyc Posted August 21, 2010 Share Posted August 21, 2010 Looks to be at just under 41 inches. Link to comment Share on other sites More sharing options...
Pete M Posted August 21, 2010 Share Posted August 21, 2010 Alright. Does anyone possibly have a measurement of a SWB 4x4 rear drive shaft with a Dana 44 rear? Just to have a number to work with :cheers: 2.5 or 4.0? auto or manual trans? lwb,_2.8,____tf 3speed,____np207,_amc20= 53"_____d35= 54"lwb,_2.8,____ax5-ax4,______np207,_amc20= 53.75"__d35= 54.75" lwb,_2.8,____ax5-ax4,______2wd,___amc20= 63.75"__d35= 64.75" lwb,_4.0,____aw4,__________np231,___d44= 47.5"___d35= 48.25" lwb,_4.0,____aw4,__________2wd,_____d44= ________d35= # lwb,_4.0,____ax15-ba10/5,__np231,___d44= 49"_____d35= 50" lwb,_4.0,____ax15-ba10/5,__2wd,_____d44= ________d35= # swb,_4.0,____aw4,__________np231,___d44= 41.25"__d35= 42.35" swb,_4.0,____aw4,__________2wd,_____d44= 52.125"_d35= 53.125" * swb,_4.o,____ax15-ba10/5,__np231,___d44= 42.25"__d35= 43.25" swb,_4.0,____ax15-ba10/5,__2wd,_____d44= 52.125"_d35= 53.125" * lwb,_2.5,____ax5-ax4,______2wd,_____d44= 63.75"__d35= 64.75" swb,_2.5,____ax5-ax4,______2wd,_____d44= 57.5"___d35= 58.5" lwb,_2.5,____ax5-ax4,______np231,___d44= ________d35= # swb,_2.5,____ax5-ax4,______np231,___d44= ________d35= # lwb,_2.5,____tf 3speed,____np207,_amc20= 53"_____d35= 54" Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 21, 2010 Share Posted August 21, 2010 4.0 Auto :thumbsup: Link to comment Share on other sites More sharing options...
juan Posted August 22, 2010 Share Posted August 22, 2010 I did this swap a couple of years ago on my 88 mj ba10. Iswapped the d35 for an mj d44. I'm used the same plates but new d44 ubolts, also I tryed using the d35 backing plates and hardware but it just did not fit so I ended up getting new d44 backing plates, brakes and hardware. I ran the d35 stock driveshaft but it was just way too close for comfort so I had it shorten an inch and now all is good. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted October 7, 2010 Share Posted October 7, 2010 I have my 44 installed with about 3" of lift on the rear. the D35 Driveshaft is installed as well and has about 1/2" of clearence before bottoming out at ride height. Now the front is 2.5" lower and will be lifted accordingly withen the next week or so I figure so ill see how everything plays out then. For now I'm running my D35 shaft with my D44 and unless i load the crap outta the rear I don't forsee any bottoming issues :smart: :typing: Link to comment Share on other sites More sharing options...
