centralnc Posted May 20, 2010 Posted May 20, 2010 I am getting closer to getting the MJ back on the road. I believe I need a new alternator. I can crank it up, but if I remove the battery cable it dies immediately. I drained one new battery already just letting it idle and run. The MJ hadn't been cranked in 4 years, so I wanted the oil to circulate and lube the engine. Would you guys buy a new alternator (~$100) or try a used one from the JY ($30)?
dasbulliwagen Posted May 20, 2010 Posted May 20, 2010 As long as the JY gives you a 30 day warranty, go get one from there, take it to autozone or wherever and have it tested... if good, install it, if not, take it back and get a different one!
ParadiseMJ Posted May 20, 2010 Posted May 20, 2010 Personally, I'd buy a new one. Not a re-man, but new. Make sure your battery is fully charged (and viable, like having it load tested) when you fire up the new one or you could damage the new alt.
kastein Posted May 20, 2010 Posted May 20, 2010 Don't yank the battery to test the alt, that trick went out of style with carbs. Doing that to an EFI rig with an engine computer is a great way to end up buying a new engine computer along with anything else containing electronics capable of emitting magic smoke.
HOrnbrod Posted May 20, 2010 Posted May 20, 2010 :agree: This can happen. No likely, but possible. The HOs are more susceptible to this as the voltage regulator is part of the ECU. Not worth taking a chance.
webbjeepxj Posted May 21, 2010 Posted May 21, 2010 I've bought 2 alts from Advance Auto ......... super nice, they test'm on the spot, and have 1 or 2 year warrenty (i think). Both have been under $100.
centralnc Posted May 21, 2010 Author Posted May 21, 2010 I appreciate all the advice. I guess I am used to doing things the old way and just taking off the cable. I put a voltmeter across the battery terminals to test the voltage. The battery voltage at rest was 12.45 V. The voltage at idle speed was 12.35V. I was expecting a voltage of around 14V with the engine at idle. The positive cable to the starter isn't in the best shape. I am going to replace it tomorrow. I will take the alternator off and test it if I have time. Did you know that Advance Auto is offering a $50 discount when you purchase $100 of parts online? A new alternator and a battery cable would qualify for the $100 and I would get a $50 coupon for the next $100 purchase. Not a bad deal for a Jeep owner. How many times do you go to the parts store and drop $100? I believe Advance is trying to promote their online purchasing system to compete with RockAuto. I am going to look in my Jeep Service manual...but does anyone know a test for determining if it is the alternator vs. the regulator? A quick test with the multimeter might save me from pulling a perfectly good alternator.
centralnc Posted May 31, 2010 Author Posted May 31, 2010 I believe I am going to have some time today to pull that alternator. I would like to ask one more question about them. RockAuto and Advance both list options for higher amperage alternators. It seems the standard is 61 amps, but 85 and 100 amp alternators are available. The price is essentially the same for the higher amp alternators. Is there any advantage to having the larger alternator? I don't plan on adding extra lights or anything that would demand a higher draw. I think I am going to order the standard 61 amp alternator. Thoughts?
aemsee Posted May 31, 2010 Posted May 31, 2010 Go big or stay home. If the bigger is about the same price, I would go higher output. At least the 85 amp one. I need to upgrade my 2.5 alt as it barely keeps up with the blower motor and lights at the same time.
comanche09 Posted May 31, 2010 Posted May 31, 2010 Yes go higher amp if possible, but check the pull-it yards first! I pulled a like new 100 amp alternator from the junkyard with napa label on it for $10.
