Incommando Posted May 19, 2010 Share Posted May 19, 2010 http://c2cfabrication.com/store/index.php?cPath=1_21_38 Has anyone used these guys? Or do you have any other suggestions. The passenger side loks good, but the driver's floor is bad. The seat bracket is completely rusted away, much worse than the floor, even. Link to comment Share on other sites More sharing options...
mkbruin Posted May 19, 2010 Share Posted May 19, 2010 Stick with someone who supports the board/community. http://stores.zmjeeps.com/Detail.bok?no=146659 Link to comment Share on other sites More sharing options...
bentnotbusted Posted May 19, 2010 Share Posted May 19, 2010 Stick with someone who supports the board/community. http://stores.zmjeeps.com/Detail.bok?no=146659 That would be good.. if they weren't liars. It really pisses me off how careful we, as MJ owners, have to be when shopping for parts. Those are XJ floor pans! They DO NOT fit! The front half pans in the first link may mostly work, but you'd still be on your own for the part the seat mounts to. Back half looks like XJ to me as well and would be completely useless. Might want to ask thes guys if they've actually ever seen an MJ floor. I my self had always read that the floors were only slightly different and that you could use part of an XJ floor pan. After re-doing my floor last year I would have to say "slightly different" is a stretch. Maybe about the front 1/3 is the same. I had a complete new XJ pan on hand when I started mine, but so little of it was useable that I couldn't bring myself to cut it up. BTW as far as I know there is no source for proper MJ pans. Link to comment Share on other sites More sharing options...
maddzz1 Posted May 19, 2010 Share Posted May 19, 2010 Could try here too. i think a few guys have ordered from here but not sure: http://shermanparts.com/ Link to comment Share on other sites More sharing options...
Automan2164 Posted May 19, 2010 Share Posted May 19, 2010 Stick with someone who supports the board/community. http://stores.zmjeeps.com/Detail.bok?no=146659 That would be good.. if they weren't liars. It really pisses me off how careful we, as MJ owners, have to be when shopping for parts. Those are XJ floor pans! They DO NOT fit! The front half pans in the first link may mostly work, but you'd still be on your own for the part the seat mounts to. Back half looks like XJ to me as well and would be completely useless. Might want to ask thes guys if they've actually ever seen an MJ floor. I my self had always read that the floors were only slightly different and that you could use part of an XJ floor pan. After re-doing my floor last year I would have to say "slightly different" is a stretch. Maybe about the front 1/3 is the same. I had a complete new XJ pan on hand when I started mine, but so little of it was useable that I couldn't bring myself to cut it up. BTW as far as I know there is no source for proper MJ pans. Wait, who's a liar? Rob L. Link to comment Share on other sites More sharing options...
bentnotbusted Posted May 20, 2010 Share Posted May 20, 2010 Wait, who's a liar? Rob L. That would be these guys: http://stores.zmjeeps.com/Detail.bok?no=146659 They claim that the same 1 piece (per side) floor pans will fit XJ's and MJ's. Flat out lie. Period. Link to comment Share on other sites More sharing options...
Incommando Posted May 20, 2010 Author Share Posted May 20, 2010 I bought a floor pan from Sherman for a '71 Road Runner in '95. It needed mucho massaging to work. That, and the fact that they list the Comanche as an XJ series, asks if it has the 4.0 V6, and if it is a 2dr or 4dr, gives me some concern. Has anyone used them and can recommend them? EDIT: They list their floor pans as fitting Chero/Wag/Comanche with the same part #. :???: Link to comment Share on other sites More sharing options...
lostissues Posted May 20, 2010 Share Posted May 20, 2010 I bought a floor pan from Sherman for a '71 Road Runner in '95. It needed mucho massaging to work. That, and the fact that they list the Comanche as an XJ series, asks if it has the 4.0 V6, and if it is a 2dr or 4dr, gives me some concern. Has anyone used them and can recommend them? EDIT: They list their floor pans as fitting Chero/Wag/Comanche with the same part #. :???: They are Cherokee floor pans, I bought a full length set to repair my floors and had to do a bit of work the get them to fit. My truck is more of a trail righ so the floor pans are in but do not look like a stock floor. pretty sure that all you are going to find is Cherokee floor pans. Link to comment Share on other sites More sharing options...
Incommando Posted May 20, 2010 Author Share Posted May 20, 2010 Do the floor pans come with the mounting chanel for the seat brackets? The channel and lower seat bracket on mine are rusted pretty well. The truck came with a set of XJ buckets/brackets but they do not seem to be an exact match for my bench seat stuff. Link to comment Share on other sites More sharing options...
bentnotbusted Posted May 20, 2010 Share Posted May 20, 2010 Do the floor pans come with the mounting chanel for the seat brackets? No. Because they are CHEROKEE floor pans. Cherokee seats mount directly to the (flat) floor. This is also why your cherokee seat brackets don't seem right. You may want to do some searching on here regarding seat swaps. Link to comment Share on other sites More sharing options...
Incommando Posted May 20, 2010 Author Share Posted May 20, 2010 My search skills must be week, or I used to broad of a term. Seat Swap, Seat Bracket, etc...returns so many hits.... :???: Link to comment Share on other sites More sharing options...
