bentnotbusted
    Nova Scotia, Canada
bentnotbusted's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. wise or not, you don't have any choice. You CAN NOT use the flexplates you have, it won't run. You'll need to get an 87-90 flex plate.
  2. zip, zilch, nada. Somebody may enlighten me as to some small tidbit that I've forgotten but I don't think an '89 has any mopar in it at all (pentastar on the key maybe, lol). By the '90 model year a few bits and pieces (brake calipers for one) started to sneak in, with the chrysler electronics coming in '91. Kind of ironic really given how many other manufacturers are in there. Chev steering column, alternator, and some other stuff here and there. Ford distributor and retractable underhood light (if equipped). The previously mentioned Aisin transmission, which I too will vouch for, I'm a die-hard mopar guy as well and I actually swapped out a t-flite for one in my truck. And, of course, the Renault/Bendix fuel injection system. It's an odd mismatch of pieces really, but it's all dead reliable with a little basic maintenance. I DD my car in the summer for the fuel mileage but our winter DD's are an '87 XJ with 320K kilometers (200K miles) and my MJ with unknown mileage well in excess of 500k Km. Both fire up on the first turn of the key, regardless of how cold it gets.
  3. Never bothered putting it in when I originally put the AW4 in years ago but I threw it in when I did the re-wiring this spring. Really, really glad I did. It stayed in "power" until the first time I tried driving on snow covered roads in 2wd :eek: Helps out quite abit to be able to lug it down a bit more on the hills. I'm actually finding the combination of the lower bottom end torque of the HO motor and being able to rev it lower a bit better in the snow.
  4. Depends on your particular case but in some cases the shocks may be the limiting factor in suspension droop. Disconnecting the shocks with the axle at full droop and unsupported may result in a bit of sudden unexpected axle movement. I usually support the jeep on the frame (just behind lower control arm brackets in front, just ahead of spring hangers in rear), then support the wieght of the axle on a floor jack.
  5. Completely true that you would have to re-wire the entire truck to retain the OBD1 control system. Defineately worth mentioning though that, with a few modifications, you can run that engine with the Renix system. Covered on here not long ago: viewtopic.php?f=2&t=27947 I've been running my Renix/HO hybrid since July and it works great, no issues whatsoever. I've even been fortunate enough to be able do get the thing hooked up to a renix compatible scanner and verify that everything is indeed reading and operating as it should, the ol' renix brain is none the wiser that anything has even changed.
  6. Defineately not the case. Contrary to popular myth the deletion of the power/comfort switch had absoluetely nothing to do with Renix vs OBD1. The switch carried over into the '91 model year and possibly the '92 year. (My '91 had one my '93 didn't).
  7. I almost slipped up on this one. You left out an important detail. What transmission do you have? Or more specifically is it a column shift auto? If so I'm pretty sure you're going to be limited to one from an '86-90 MJ with column shift if you want a direct swap. Not sure if these came in tilt versions or not. If it's not column shiftr you'll also be able to use '84-'90 XJ columns as well. Lots of those in tilt for sure.
  8. Have you followed the proper, comanche specific, brake bleeding procedure? Seriously, there is one and you won't get decent back brakes if you don't follow it. Search for brake bleeding procedure on here and you should find it.
  9. Not tremendously useful information but hey, thought I'd throw it out there anyways. Numerous times I've come across people looking to convert thier 2.8 or 2.5 MJ to a 4.0 and invariably the topic of using an XJ wiring harnes comes up and the fact that you have to modify the taillight wiring to make the XJ harness work. Right? Not 100% it turns out. Me and the better half were driving along in her XJ Wagoneer the other day and she mentioned how her tailights seemed brighter than her other XJ. They are. Because they use 2 marker light bulbs like an MJ! MJ and XJ Wagoneer taillight wiring would be the same. So there you go, if your looking for an XJ donor for your MJ 4.0 liter swap keep an eye out for Wagoneers and save yourself one little tidbit of extra work.
  10. If he puts his renix stuff on a newer 4.0l I doubt he will gain much power,also his renix stuff won't just bolt on to a HO head so he would have to use his head which probably has a blown head gasket and maybe other issues or convert his truck to HO manifolds As long as the only renix stuff he uses is the sensors and mounts (as in he does do the manifold conversion), there would indeed be a very noticeable difference in power. I've had the oppurtunity to sample numerous variations of the 4.0 over the years (3 stock renix's, 1 lightly modded renix, 2 stock HO's and now the HO/Renix hybrid). I'd gladly challenge anyone to differentiate powerwise between the Hybrid and a full HO. Keep in mind though that the power comes in a completely different RPM range. While I thoroughly enjoy the added top end power I do sometimes find myself missing the low rpm grunt of the renix motor. One hill in particular in my daily commute the renix motor would pull up in OD at 1600-1800rpm, HO motor has to downshift to 3rd to maintain the same speed. Also since we seem to have gotten into a bit of discussion on blocks and such I thought I'd throw in my $0.02 on that topic as well. Only really applicable for someone building up a motor (or considering keeping thier current one I suppose). I had the oppurtunity to tear down a few well abused 4.0's this summer and observed first hand one of the major differences in the various blocks. The High nickel alloy of the renix era block is indeed super hard! The 300k '91 block out of my XJ showed significant cylinder wall wear as I expected. The 500+K renix block out of the MJ still has visible cross-hatching the full length of the cylinder walls, even in the cylinder with 2 broken rings. I had heard that the blocks were harder but I was truly surprised to see the real-world difference.
  11. You do not need to re-wire your whole truck. You do not need to live with mismatched intake ports. It's entirely possible to drop the entire HO engine in with almost no wiring mods at all. Use the HO manifolds (and exhaust down-pipe as previously mentioned). You'll have to adapt the Renix TPS to the HO throttle body and swap over all the rest of the sensors. One of the temp senders gets relocated to the thermostat housing so the wiring for that will need to be re-routed. Someone makes a kit to adapt the TPS (Hesco?), but if you get creative you can do it yourself. You'll also need the Renix Distributor. HO oil filter interferes with the EVAP canistor so you either have to swap the filter adaptor or relocate the canistor. You'll need the HO vacuum lines and airbox as well as the HO throttle cable. There's some debate, by the way, as to whether or not the HO blocks are threaded for the knock sensor, my '93 block was. I think probably the most difficult part was dealing with the different fuel lines. I used some aftermarket line and fittings to adapt the HO fuel rail to the renix lines. A friend of mine running a very similar setup fabbed brackets to retain the Renix feul rail. I've probably forgotten something here but this is how I did mine. Way easier than ripping the entire cab apart (in my opinion anyway), and it works great. edit: yeah what jpnjim said. And I forgot the alternator (and brackets). Oh and it's still only one TPS with an auto, it just has two plugs.
  12. No. Because they are CHEROKEE floor pans. Cherokee seats mount directly to the (flat) floor. This is also why your cherokee seat brackets don't seem right. You may want to do some searching on here regarding seat swaps.
  13. That would be these guys: http://stores.zmjeeps.com/Detail.bok?no=146659 They claim that the same 1 piece (per side) floor pans will fit XJ's and MJ's. Flat out lie. Period.
  14. That would be good.. if they weren't liars. It really pisses me off how careful we, as MJ owners, have to be when shopping for parts. Those are XJ floor pans! They DO NOT fit! The front half pans in the first link may mostly work, but you'd still be on your own for the part the seat mounts to. Back half looks like XJ to me as well and would be completely useless. Might want to ask thes guys if they've actually ever seen an MJ floor. I my self had always read that the floors were only slightly different and that you could use part of an XJ floor pan. After re-doing my floor last year I would have to say "slightly different" is a stretch. Maybe about the front 1/3 is the same. I had a complete new XJ pan on hand when I started mine, but so little of it was useable that I couldn't bring myself to cut it up. BTW as far as I know there is no source for proper MJ pans.
  15. Not sure where you got that info but I assure you it's wrong. There are 2 limiteds here in my driveway and they both have factory rear swaybars.
