Bad luck , Murphy's law or just plain EF'ED ???
So for the last two and a half months I've been working on my complete axle and suspension upgrade .
Parts list :
RE HD SF 5.5" lift kit ( short arm )
New D44 w/Trac-lock , alloy axle shafts , TF disc brakes , seals and Yukon 456"s
Complete rebuilt D30 w/ matching gears
Tera Flex SOA kit
Tera Flex SYE kit
Custom made Tom Woods CV drive shaft
HD Tera Flex rod ends
TF high steer 1 ton knuckle kit
Custom made drag link and tie rod @$$.
TF sway bar relocation brackets
RE quick disco's
Bilstein / RE mono tube shocks
So after a astronomical amount of money and long waited anticipation , AH the test drive .... Not even two miles down the road and
The rear locks up like a horse that won't jump over a creek , locking all four tires at 35 mph , so there I sat right in the middle of the
road all locked up and no where to go . She wouldn't budge , no neutral , back or forward .
By this time I'm sheer meltdown mode because everyone that drives by me looks at me I'm THAT GUY who won't push his crap off to the
side of the road . Then comes the cops , intro with " what did you do " really dude ? I planned all this out . " OH well can see your license
and registration please" , seriously dude ?
The only way we could get the truck on the skid was to drop the drive shaft right in the middle of the road , with rear still locked up
we dragged my brand new sh@t right up on the skid .
I know this kind of stuff happens to the best mechanics but man I had to vent some steam . It was either kick the dog around for a day or
post a big @$$ long blog about how my panties are all wadded up .
Thanks for being my emotional punching bag CC . :thumbsup:
happens to the best of us sometimes. My 88 overheated 5 minutes into its first wheeling trip. :shake:
So did your D44 lock up or was it the T-case? I am a bit confused.
In any case, that sucks!
At first I thought it was the T case considering the D44 had less than 2 miles on it but nope after disengaging the drive shaft
she told the hard cold truth that all the money and work that went into that rear end was kaputt .
Hopefully when the shop calls me I'll hear a little better news . Good thing is they are the ones who built it so now they have to build it
again .
The rear end did have fluid in it... right?
Wouldn't be the first time......
OK , so the guys down at the shop felt so bad that they burnt some midnight oil and are working on rebuilding it by today .
None of us know what the actual deal was with the rear but never the less new gears and bearings is what she needs .
I'll probably have it out by noon .
I've been excited to throw down some pics so maybe by this weekend I'll have them up for anyone who cares .
and this is why I shy away from installing gears. Something goes wrong and it can take out everything in one fell swoop (including your whole truck as you almost found out). :(
Yeah thats why I left this one to the pro's who have made all the mistakes before , I knew my skill level was far under par for a custom
CV drive shaft and SYE kit , I'm just a plain ol' metal smith with a couple of wrenches .
However I couldn't go on with the ever hated 307's , maybe a smaller gear set up would have been better but my plans are to go with
a 33x12.5" tire and probably be towing a small bike trailer or utility trailer at some point as well .
Pete, 5.13s turned my TJ into a toatly different animal. Well worth the cost and 3 hour trip home (usually 45min but I had to let them gears cool down). The risk of issue is worth it and should be a non issue if a decent shop does the work.
I got my truck back and it runs great , I'm still a little gun shy with what happened and all but the but the culprit ended up being a faulty
axle bearing right out the box , yep the gears after and she was history .
So I'll be a little shy on it for now .
Damed skippy , she turns them big tires with 0 problem now , gets up in to gear so fast you don't even know the tires are there .
Just for $#!& I threw a buddy's trailer on to see what happened , other than the trailer being to low for my truck I didn't even know it was
there . I almost yanked my mail box right off coming in the driveway because after a couple of minutes ridding around I forgot it was there .
It is now a completely different truck .
OH yeah pete , I don't want to go through this again anytime soon so she's a pavement queen for right now , probably get a couple hundred
miles on it before I actually throw any kind of load behind it and no heavy wheeling until then as well . DR ORDERS , remove lead foot and
no heavy metal coming from the juke box either for thats the gateway drug to nascar style driving .
I broke my gears in corectly. 200 miles of short trips followed by a lube change. Then I spent a week on the Colorado trails, about 400 miles. :clapping:
Glad to hear she is purring down the road. But where is the eye candy!!!!???? We need pics!
