So I have this nice clunking noise when I come to a stop/coast below 10mph. I grabbed the driveshaft and felt and saw the play in the u-joint closest to the tranny. I went to AA to buy u-joints and all 6-8 of them were specified 4wd. Does the 2wd use the same u-joints as the 4wd? This is an '88 2wd BA10 Eliminator.
Yup, they are the same. just make sure you buy driveshaft joints and not axleshaft joints. :thumbsup:
yep greased one so good, it broke the retaining clip and flew right off the front yoke :D Exactly one minute before I was about to wheel.
(Could be that I was smashed drunk installing it) :cheers:
  • 5 years later...
hate to resurrect such an old thread...but i guess better than started a new one with the same question...
What is the spicer part number I need for both/either the front and rear driveshaft u-joints? Mentioned above is the Spicer 1310...but is that specific enough? Sorry, just don't want to order the wrong stuff. Would this be the S-153X?
And is greasable really better in these locations? I replaced the front with non-greasable because they are a little stronger...plus the OEM ones are not greasable, right? Least they aren't in my rig...
Thanks!
I have the 4x4 4.0 5-speed MJ if it matters.
Yes, regreasable joints are better - if you regrease them. Regreasing the joint provides fresh lubricant and flushes contaminants (water, mud, etc.) out of the joint and therefore prolongs the service life. As Hornbrob said, regrease with a hand grease gun. The powered guns can develop enough pressure to damage the seals.
Non-greasable joints are lower cost because it takes less machine work to make them. OEM parts are usually selected based on (a) meeting a minimum performance specification and (b) lowest cost. It's never wrong to use better parts, especially if you plan to use your vehicle for heavier duty service than the original design.
Either Spicer 5-153X U-Joint (greasable) or Spicer 5-1310X U-Joint (non-greasable) are fine - your choice.
For the greasable joints, I remove the supplied grease fittings and replace them with 1/4 x 28 "flush" type fittings. This makes it much easier to grease the joint by using a needle attachment on the grease gun.
Hi everyone,
Sort of off topic here.
Universal joints for front axle shafts (88, obviously four-wheel-drive.)
My right side has greaseable joint, the grease fitting was in the cross itself. This fitting broke off, every once in a while I try to shoot some grease into the broken stub of fitting that remains.
Left side has greaseable U joint, with the grease fitting in the bearing cap. When I grease this, grease will ooze out of three of the bearing caps, not out of the fourth.
So I imagine  eventually I'll have to replace these. I'd like to stick with greasable, and I think fitting on the bearing cap is better.
Yes? No?
And if anyone has Spicer part numbers, that would be greatly appreciated
Thanks.
Gene
