fiatslug87 Posted May 1, 2010 Share Posted May 1, 2010 Which welder do you prefer in general? Mind you, this is for general novice/advanced-novice MIG applications. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 1, 2010 Share Posted May 1, 2010 Both are fine, both do the same job, work just the same and nothing appreciable differences between them... accept cost. Lincoln is more costly so I voted Hobart. Now for the other questions. Buy a 220v unit if you will only have one welder. If you have a buzz box or the ability to use a big MiG a smaller 115V unit is OK. Even then buy the biggest 115V available. I have a Hobart 140, very nice machine. I haven't found a limitation in using it, but I don't even try to use it on steel thicker then 1/4". I use a Buzz box for that stuff. Good luck, CW Link to comment Share on other sites More sharing options...
Lenard Posted May 1, 2010 Share Posted May 1, 2010 I voted for the Lincoln, only because that is what ive run the most, i have run a couple Hobart's, nothing wrong with them, i just like the Lincoln look better :chillin: but CW is right, hobarts are cheaper, so unless you have deep pockets, hobart would be the way to go. Mig welders are so nice to have. the other day i built a muffler for John Deere Dozer using the mig, it came out beautiful. Including the torch gas used and wire and gas used in the welder I built the muffler for $30 with scrap metal, new muffler from John Deere-$260 :hmm: And mine looked better than the one from JD. Lying, cheating bastards. :rant: Link to comment Share on other sites More sharing options...
Yesterday's Danish Posted May 1, 2010 Share Posted May 1, 2010 We use Lincoln's and Miller's at school. Both are great machines. I'm sure the Hobart's are nice, too. CW is right, make sure you get a machine with enough power. I stick welded on 3/8 inch carbon steel without any problem on a 220V welder. Link to comment Share on other sites More sharing options...
jimoshel Posted May 1, 2010 Share Posted May 1, 2010 Couldn't make up my mind whether to vote twice or not at all. I am currently running a Lincoln Ranger , a Hobart buzz box and a Century wire feed. All great. Really couldn't pick one over the other. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 1, 2010 Share Posted May 1, 2010 a harborfrieght welder is gonna stick metal together so you should be fine with any decent brand name welder Ive had good luck with lincoln,miller,and century. never used a hobart but i can't see any reason it would have problems. theres really not much to a welder,just make sure you buy one that can be serviced if you do have a problem or need to buy parts. Link to comment Share on other sites More sharing options...
Darren Posted May 2, 2010 Share Posted May 2, 2010 I'm voting for Lincoln because they look better. That shiny red case is just so sexy, especially compared to the cream colored Hobart. I just bought a 220v Lincoln SP-180 and I love it. Definitely get a 220v model. A welder is a big purchase, so you might as well get one that will last you a long time. If you get a 115v you'll eventually wish you went with 220v. Link to comment Share on other sites More sharing options...
